Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My Book makes clicking noise and does not show up anymore
Help! I have all my files on MY Book and until today it worked great...now it clicks when I plug it in and my computer does not seem to recognize it anymore. What can I do??? Thank you for all the help! Merry Christmas! Hi Its the same over here, first there was an error message with writing away something and now only the clicking until it stops completely.
  • Anonymous Oct 16, 2008
    My drive
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    clicking is not too cool...that means that the drive is truly unhappy...got a local disk recovery place?
  • 6,831 Answers
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Posted on Dec 08, 2010
Verbatim store n go 64gb flash drive working fine until today it has 49gb of data on but will not show any of it in any pc i put it into please can anyone help
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
It might take some time depending on the of the disk
be patient then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 you might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this or if i have missed the problem post a reply Hope this helps.
Dec 11, 2012 | Verbatim Store 'n' Go USB Flash Drive,...
My wd external hardrive is not recognized anymore on my pc. I have tried on other pcs and tried different usb cables and nothing. I do not want to reformat the drive because I have important information...
Hi. If you here some clicking noise then your external hard drive might be busted already.
Try to contact a local tech and see if he can still pull out your data from there.
Hope you'll be able to extract your files back.
Have a great weekend!!!
^_^
Jun 04, 2010 | Western Digital My Book Essential 320GB...
Hard drive is not working.
The clicking noise is most likely the hard drive trying to restart or start the drive i think the motor is not turning thus no data being sen nor received
Apr 13, 2010 | Iomega 750GB Esata/usb 2.0 750 GB Hard...
Hi, My 1T WD Drive will not show my files. The "my book" yellow icon shows up on my desktop and once I click upon it, it shows that I have 25 folders in the contents label but the folder does not show any...
Maybe your files are'hidden' ??! Enable to view hidden files by:
  1. Right-click the "Start" button, then select "Control Panel".
  2. Go to "Appearance and Personalization", then select "File Explorer Options".
  3. Click the "View" tab.
  4. Scroll down a bit and change the "Hidden files and folders" setting to "Show hidden files, folders, and drives".
Feb 02, 2018 | Western Digital My Book Home Edition 500...
Clicking noises before TV turns on.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
Nov 07, 2009 | Samsung LN-S4052D Television
I used my hard drive with great success for a while now, switching it between several computers. Today, however, it wouldn't register anymore, my computer won't see it. It makes the sound when i plug it...
Sorry to inform you that the HD is starting to quit working. Clicking sound is the indicator that it's no longer responding. There could be some bad sectors in the HD.
You may want to check the Disk Management of your computer to see if you could still reformat the HD. Bear in mind that reformatting the HD would erase all the files saved in it.
1. Connect the HD to the computer.
2. On your computer screen, locate "My Computer" or ""Computer" icon and right-click on it.
3. Click on Manage and then select Disk Management.
4. Write down all the drive letters that would appear.
5. While the Disk Management is opened, unplug the HD and see which drive letter would disappear.
If there's no drive letter that disappears, meaning that the HD is no longer recognized by the computer.
Try bringing you HD into any computer store that offers data recovery.
Aug 07, 2009 | Western Digital My Book Essential 1TB...
My Book 500 GB
Same problem here. I did recover some files when I commected it to another PC!!
WD should get this sorted as lots of peoples data is being lost.
Please let us know of a solution if you can?
Sep 21, 2008 | Western Digital My Book Essential Edition...
I'm a novice, but know enough to be dangerous, so I scrounged the internet trying to find a fix when this happened to me two weeks ago. I was devastated because of course I was too dumb (and cheap) to buy a second hard drive to back up the data on my first one. Lesson learned. Anyway, data recovery was 3 grand or more and I can't afford that so I took the advice of a bunch of people and tried the crazy idea of putting the dumb thing in the freezer. I took the case off using instructions I found on the web and then wrapped it in a white flour sack cloth to absorb moisture and put it in a ziplock in the freezer. After 24 hours freezing I tried again, nothing but obnoxious clicking. Going into Control Panel/Administrative Tools/Computer Management/Device Manager I could see the drive but it said there were no partitions. Windows Explorer wouldn't assign a drive letter. I threw it back in the freezer for 10 days and on a whim last night tried again. The USB 2.0 port on my XP computer is broken and everyone told me not to use Vista if I could help it. So I took a USB hub and plugged the new hard drive in first and let it boot up. Then I took the frozen hard drive and plugged it in too and I was SHOCKED when Autoplay started running. Maybe the drivers and software from the good drive allowed the bad one to boot up. I don't know. I just know that it didn't work plugged in directly to the USB but it did via the hub.... Anyway, I have cords running out of the freezer into my laptop which is perched on a chair outside the freezer. I got all my pictures and priceless data off this drive overnight. It did stop a few times (says it can't find the file and the drive stops spinning) and I was able to unplug it, plug it back in and get it going again. It is SLOWER THAN MOLASSES and I would strongly suggest prioritizing your stuff so you get the most important data first because you don't know how long it will run, but I am thrilled beyond belief I got my pictures and home movies back. People told me I was crazy and stupid for freezing a hard drive, but it worked for me so I'm not going to question it. My data is on the new hard drive which I am immediately going to back up onto a second and I will live happily ever after because I didn't need to spend thousands to get my data back. Good luck!
Aug 13, 2008 | Western Digital My Book Essential Edition...
Address book help / won't open
Reset the phone by removing the battery for 10 seconds. That should release the application freeze.
May 20, 2008 | RIM BlackBerry Pearl 8100
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
157 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
