Question about Compaq Keyboard
Sticky keys My comma won't work and when you don't need it it appears endlessly. I have the same problem with the letter m before. Now comma has the problem and the mouse's right click. up and left arrow keys and ctrl and alt do not function.. It's a burden. Help me.
    Genius:
  • 1,061 Answers
Your keyboard needs cleaning.RICHARDM69
Posted on Dec 07, 2008
Notebook eee900 series won';t let me log in. It prints commas rapidly nonstop or sometimes one letter. example ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,this goes on and I cannot interrupt
Dear Raisa,
It seems that the comma key has some mechanical problem. Maybe there is something that entered under the key and is keeping it depressed. Maybe it is the contact matrix under the same key that is defective, making a permanent contact in this key. Although there are some videos in YouTube that show you how to change keytops in laptops keyboards that could help you disassemble the ',' key, check if it is clean and free, and replace it, it is not a very simple task. You should better take it to a repair shop and have it checked by a service technician.
Hope it helps!
Regards,
Miguel L. Martins
Nov 04, 2013 | ASUS Eee 4G Notebook
Commas
Dear make your password mix of letters, hyphens, spaces and commas. Hope it works
Jul 02, 2013 | PayPal Computers & Internet
HP 15C commas and decimals interchanged
Turn the calculator off, press and hold the decimal point key, press ON, then release both keys.
Apr 20, 2013 | HP 15C Scientific Calculator
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
Some letters of my toshiba laptop keyboard is not working like letters q, s, d, g, j comma, period and numbers 1 and 6
Hey there , I too had this problem with my Laptop keyboard, 8 of my keys stopped working, after a long search i found this company that i ordered my keys from, i am really satisfied with them as they have great service and easy installation video's that helped me fix my keys the same time.www.laptopkey.com
Oct 12, 2011 | Compaq Keyboard
Some keys doesnt work like the comma dot question
the problem may be of the sticky keys or of the keyboard. no else problem is seen in the keyboard.. so, if sticky keys are enabled, disable it from the accessibility options in control panel else change the keyboard !
May 08, 2010 | Gateway MX7120 Notebook PC Notebook
Keys don't match letters
On the L. side of the keyboard is the pitch selector switch it may be in PS proportional space it should be in 10. 12 or 15 also dlide it up & down a few times they do get dirty.
DickyO
Jan 05, 2010 | Nakajima AE-710 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
Sticky keys
You can try cleaning the keyboard. most keys can be removed easily by just pulling them out.
This will require about 2 hours time once you have collected the proper cleaning materials.
  • Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive.
  • This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows: DISASSEMBLE
IMPORTANT: Make a keyboard map so you know where each key goes.
Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.
CLEAN KEYBOARD ( do this well...... you will be wonderfully rewarded )
Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol.
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease.
Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don�t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD
Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry.
All right, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
Place all rubber components into the keyboard.
Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place.
Install the rest of the keys by aligning and firmly pressing down.
Nov 16, 2008 | Compaq Keyboard
Sticky key
i have the same problem with letter m before and now comma has the problem!
Jul 26, 2008 | Compaq Keyboard
Compaq Keyboard Logo
131 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
