Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 model# 11042822201
I hooked up my washer, turned it on and water began spraying out of the seams in the back of the machine. I took the top off this morning and noticed a plastic part that the hot/cold hoses hook into is cracked. On top of this cracked piece is two cylinders (look like fuses) which attach to an electrical panel w/in the machine. Is this going to be a hard job for me to fix myself? I don't think so. I just need help in how to get the other small hoses unattached from this cracked piece. I tried to pull them off, but of course they are very tight. I was thinking of trying to spray them w/WD 40 to loosen them. Then I'm thinking, if these are so tight trying to remove them, how will I get them back on the new piece??? Should I just hire a repair man? I am strapped for money right now and am pretty mechanical. I just need to know if anyone else has had this issue and if you can help me. Marie
  • fupulusch Oct 16, 2008
    I found out the part I need to replace-Valve inlet part# 8181694. Also, how do I disconnect the part from the machine?
    Thanks,
    Marie
  • 1314 Answers
SOURCE: KENMORE ELITE HE 3- MODEL 44832200
is the washer full of water and is the sound like a fast clicking
Posted on Dec 31, 2007
  • 16 Answers
SOURCE: removing panel cover
Sounds like your drain pump is clogged.
Posted on Nov 23, 2008
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
  • 686 Answers
SOURCE: Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Posted on Apr 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore elite He3 leaking water into tub
Outstanding diagnosis. You are correct to assume a water inlet problem and, "yes", this can be a common problem. If you live in area that has hard water, or if you use well water, sediment, rust and calcified deposits can clog the small diaphragms inside the valve causing them not to close properly and leak by. You can attempt to clean the valve by removing it and submerging it in a 50/50 solution of distilled vinegar and hot water for about 30 minutes, Sometimes this can dissolve any clogs and restore the valve to full operate. However, if this does not work, you will need to replace the valve.
The following link explains the steps required to replace the valve if you need directions:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I have included web resources to search for replacement parts.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on May 30, 2010
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
We purchases a uses kenmore elite washing machine. When we hooked it up, and put the first load in and turned it on, water sprayed inside and leaked. We imediately unplugged the machine. Now we can
use a t-20 torx or a 7 mm socket to remove the toe kick under the door. then on the right side under the door, reach up inside the front panel find the door lock. at the bottom of the door lock you will feel a flat circular tab. pull the tab about a half inch and PULL ON THE DOOR AT THE SAME TIME.. then start washer and see if you can determine where water is leaking. if you can replace a simple part and repair it, use your model# and do a google search for parts.
May 13, 2012 | Kenmore Elite 45986 Front Load Washer
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore Washing Machines
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 fills but won't spin
do you hear any sound while stops??
like ticking sounds?
Jul 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
135 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
