Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Television confusion trying to switch over screens on my 46 inch sony the control adjuster for sound and channel change is attached to the old lcd screen how do you remove it
  • 320 Answers
You're changing the panel? I wouldn't recommend a consumer doing a panel swap, as it is very easy to mess things up.
Posted on Oct 18, 2008
Using another model lcd panel
yes this should work if the screen connectors match up!!
Mar 02, 2013 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Samsung 46 inch lcd no picture only sound
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
Feb 08, 2012 | Samsung Televison & Video
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
46 inch sony picture too wide cant adjust with remote
If the Dish remote won't change the picture size when you use the "Format" button (either bottom left on remote or the "page up", "page down" buttons), then you will need to try the Sony remote. If the Sony remote doesn't have a "picture size" or "format" button, then enter the Sony User Menu and look in "Set up" for "Picture Size" "Format" or the like.
Hope this helps!
Jun 12, 2010 | Sony Televison & Video
Blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Nov 14, 2009 | Televison & Video
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Yes, you do need to get the LCD repair before the warranty expires. Call the manufacturers to find an authorized service center near you.
Good Luck.
Aug 15, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
