Question about HP Compaq Presario 2200 Notebook
Command promt not openin
Hi all
i got one autorun virus detected and deleted by avg antivirus. but now my cms promt, device manager are not gettin opened.wat to do????
    Novelist:
    Scholar:
  • 84 Answers
You may try rebooting your computer to Safe mode w/networking. Try your command prompt in safe mode with networking. Download and run the program on the link. This would fix the registry of your system.
http://tinyurl.com/4paxty
You need to run the registry checker on this application as well. You will have the option to fix the corrupted registry..
If you can access the command prompt. Insert your windows XP or VISTa cd then on the command prompt. run this command
sfc /scannow
Restart your computer.
Kind regards,
Jeff
Posted on Oct 18, 2008
Universal serial bus virus delete
Start ->run -> type cmd -> type attrib -r -a -s -h *.* and press enter.
What this basically does is removes the read only, archive, system and hidden file attributes on the files so that the virus or the container of virus will be shown.
Within the command prompt you will run the delete command to delete these suspicious files as the are shown up, example type del Autorun.inf or del New Folder.exe.
When you have finished doing that unplug your flash drive, update your anti-virus and scan your entire system.
Last but not least plug back your flashdrive into your computer and scan it with your anti-virus.
Viruses on flash drives are usually spread because windows has the Autorun feature set automatically run by default and this needs to be disabled.
Here is the easiest and fastest way by far to disable the autorun feature.
Download Disable_autorun.reg registry key.
Click Save to your computer ->Rigt click on file -> click run
Click Yes to confirm addition to the registry
http://www.majorgeeks.com/Kingsoft_Free_Antivirus_d6512.html
Kingsoft provide a complete and powerful security solution for personal users. Kingsoft Free Cloud Antivirus defends against viruses, spywares and malwares real-time.
Detect all type of virus and threats with multiple guards.
It include USB device protection, disk cleaner, History cleaner, process supervisor, LSP repair tools and system repair.
hope this helps
Sep 09, 2012 | Targus Acp45us1 Docking Station. Docking...
I have a Toshiba flash drive. I used to plug in to computer and it would ask if I wanted to scan, now I plug in and it opens automatically. It will not let me add information and save. A message comes on...
Hi uva5,
This seems to be a problem as a result of auto run virus which has probably infected your flash drive, an autorun virus modifies the autorun.inf file in the root drive of your flash drive so that it can execute commands that are mentioned in that file, most probably , it will execute a .exe file which is hidden in your pen drive by the virus so that your flash drive malfunctions and takes up much of your memory , i.e. physical memory used to run programs faster to which we call RAM.
I would recommend you the following steps to make sure that your drive is functioning properly.
  1. Do a through scan of your flash drive and make sure that it's virus free , by a reliable antivirus software , there are some good ones available for free, I would recommend you download AVG free version if you don't have one , so that you can use it to scan your flashdrive. http://download.cnet.com/AVG-Anti-Virus-Free-Edition-2011/3000-2239_4-10320142.html
  2. After you scan your flash drive , and the anti virus heals the detected viruses or deletes them , you should not have this problem.
Hope this helps.
May 11, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I am unable to delete Rahul'virusprotection.vbe and Autorun.inf in my pen drive .Sometimes deteled again immediatly come to my pendrive
Please follow these steps to Remove Virus using Command Promt:
Click the "Start" menu and type "CMD" into the "Run" box and click "OK."
Select the drive that is infected with the virus. If you are not sure which drive is infected, start with the "C:" drive. Type in "C:" and press "Enter" to access this drive.
Type the following into the command prompt box: - s - h *. * /s /d and press "Enter." This will bring up any suspicious files located on the drive. Open the suspicious file.
Look for a file that contains a ".exe" file and a file titled "autorun.inf." If you find these two files, you have found the tainted file. Make sure to write down the name of the program where the file is located.
Rename the "autorun.inf" so you can access the drive later without activating the virus. Type: rename autorun.inf as virusfile and close out of the "Command" prompt box.
Double-click the "My Computer" icon and select the drive that has the infected file. Find the program that contains the infected file.
Right-click on the program and choose "Open."
Right-click on the file you renamed "virusfile" and choose "Delete."
Right-click on the ".exe" file and choose "Delete." You have now removed the virus from your computer's hard drive.
Feb 27, 2011 | Computers & Internet
How can i delete TR/Dropper.Gen? AntiVir detects but wont delete or remove or move to quarantine
go to the trendmicro online virus scan. It will automatically detect and remove all viruses for you - FOR FREE go here and follow the instructions: http://housecall.trendmicro.com/
Nov 04, 2009 | Microsoft Windows XP Home Edition
Surabaya in my birthday
If you are getting message like" Surabaya in my birthday, Don't kill me, I'm just send message from your computer", then it obvious that your computer is infected with Surabaya Virus
Symptoms of Virus
1) All folders get disappear.
2) Folder options not work.
3) Machine Restarts on running command like msconfig , regedit.
4) You are unable to install many antivirus.
5) Folders name appear with scr extension ( Actually not folders)
Reasons of infection
1) Infection from removable drives e.g. pendrive, hard disk,
2) Reading cards using card reader
3) From CD or DVD
4) From others computer
5) From internet
Remedies:
1) Using free software:
Download the "Autorun Eater" from internet ( 1.5mb)
Download from:
http://oldmcdonald.wordpress.com/
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
a) Install "Autorun eater" ( some Antivirus detect it as a virus but it is safe) and run it. It appears at taskbar ( lower right corner)
b) Right click on it and follow following path
Registry fix>>fix folder option.
(This will repair folder option and it will appear in tool menu)
Now you can see hidden folders
But Surabaya virus change your folder attribute to system folder. So to see your folders you have to untcheck option " hide protected system files and folder" which appears
Right "below the show hidden files and folder" option
Path:
Open my computer>>tools>>folder option>>view>>uncheck show hidden files.. and hide protected system files and folder
How to change folder attributes to normal
You can use command prompt to change the folder attributes
A) Start MS-DOS command prompt (start>>program files>>accessories>>command prompt
B) Type drive letter and attrib command
D:\Attrib *. * -S -H -R /D /S ( Put space between /D and /S switches.)
This will change your all folder option to normal
1)Manual:
a) type "regedit" at command prompt..STRAT>>run>>regedit
b) Search word 'surabaya' in registry...Edit>>find>>Surabaya
c) Delete two entries appeared in search as " LegalNotice Caption and LegalNoticeText"
d) Now using left option tree navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\showfile
check value 0 to 1
Autorun Eater software:
Autorun Eater software helps to protect and remove autorun virus which generally infects from external storage device and internet. This small software is very helpful in conjunction with any antivirus software even it alone can protect your computer from autorun virus(but not complete solution).
(C)infoall , legal: Use above information on your own risk
Mar 21, 2009 | Microsoft Computers & Internet
Can not find script file "C:\ntidr.vbs"
by alvin:
just go to command prompt, click run then type cmd..
after that type dir f:\/a/w if letter f is where your drive located..then you can see the contents of your drive ..you will see an autorun.inf...
you should delete that...in the same cmd window
type attrib -r -a -s -h f:\autorun.inf
then type del f:\autorun.inf....eject your flashdrive...goobye ntidr.vbs..
Sep 21, 2008 | Microsoft Windows XP Home Edition
Vanti virus trojan autorun...
update the virus database of mcafee antivirus software.Contact them by providing your system information report.If it is a legal software u will get support from them.
Regards.
ucp_pru
Jul 23, 2008 | Computers & Internet
How can i remove virus worm/autoit permanently
its simple guys..!!!
if it asks for permission to access outlook..don't permit it because it is a smart virus and is going to spread it to all the people on your contact list...!!!
simply open task manager and end process tree of KHATRA.exe , gHost.exe , xplorer.exe and OUTLOOK.exe seperately...!!
then run your anti virus or download one if you don't have one..!!!
run a complete computer scan in detail..!!
then delete all files which are infected by the virus because the results contain only duplicate files which are created by the virus
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
To remove virus from pen drive
Open Command.
type the drive name say H:
then type ATTRIB -H -R -S AUTORUN.INF
then type EDIT AUTORUN.INF
then a new window appears, delete all the contents and click on File -> Save and click on File -> Exit
type ATTRIB +H +R +S AUTORUN.INF
then type EXIT
Remove the pen drive and reinsert it.
The virus is now been deleted.
My mail id is overthehedgerj@gmail.com
Contact me if you need my help. Thank You
Oct 24, 2007 | LG KU990 Viewty
HP Compaq Presario 2200 Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
