Question about Onkyo TX-SV444 Receiver
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
Good relations Onkyo and loudspeakers.
I am bying loudspeakers, but I am worried about their impact on my Onkyo TX-SV444.
    Problem Solver:
  • 13 Answers
Buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Posted on Mar 04, 2009
Onkyo tx-rs605 no power
It likely needs to be opened and looked at---a fuse is possible or may be a good idea to take it to a shop for an estimate.
Jun 26, 2012 | Onkyo TX-SR605 Receiver
Onkyo TX-NR801
is the mute indicater displated on the screen.
Jul 12, 2008 | Onkyo TX-NR801 Receiver
Tx-sv444 says protect then powers down, cannot get to stay on for more then a few seconds
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 20, 2011 | Onkyo TX-8211 Receiver
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
Amp protection circuit has been activated
1-check your input cables from connected equipments(cd player or dvd p
layer or any other media source).
2-adjust your input signal level(from-10 db to 0 db).
3-amplifier power must be bigger than total power of all loudspeaker with 20%----(if total power of loudspeaker is 8 watt amplifier must be 10 watt.
Nov 28, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SV444 problem
the shorted spkr wires probably fried the putput transistors in that channel.  Do you know how to use a Fluke  test meter on diode test
Dec 31, 2008 | Onkyo TX-SV454 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Reciever wont go on
Your are running out of power !!
Feb 02, 2008 | Onkyo TX-SV444 Receiver
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
448 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
