Question about Averatec 3150H Notebook
Averatec 3150h monitor problems
Monitor will flicker on and off at times - no always. You can still see the image but it is very faint. Not consistant and can't tell if touching certain areas helps or not. Is this a backlight problem and how can I replace it if it is?
thanks
    Genius:
  • Averatec Master
  • 1,250 Answers
This is the problem of display cable that gives display to the screen consult the technician near you
please rate this solution
Posted on Oct 16, 2008
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Im having issues with the hanns-g hg281d. my screen is always faintly flickering, especially when the screen is on darker colors
i was having same issue.i would turn off monitor for 10 secs. then turn on .and it would not happen for a while .i went to i cable and it now rearly ever happens.
i use this as a external monitor for my laptop for 6 mons.now.
Jan 04, 2011 | Hannspree HW191D LCD Monitor
My display flickering
1. Check the cables for lose connection in the connectors.
2. Check if there are interferences of magnetic fields from other gadgets.Yes, check if near your laptop, you haven't placed speakers, florescent lights, cell phones, radios and any other electrical device.
3. Check if there were any changes in the display settings like when some computers are upgraded from their original versions. For instance, many laptops that have been upgraded from Windows 95 versions to higher versions, have shown problems of flickering due to poorly calibrated refresh rate.
4. Many a time, it may occur that the pixels on your LCD laptop screen/LCD Monitors are damaged in certain area and so you're unable to see proper images. If that is the case, then you don't have any other choice but to change the entire screen and replace it with a new one.
5.To check if there is no problem in your video card, connect another monitor to your laptop through the VGA port. If it shows any faint images or jumbled images, then the main reason for your laptop flickering screen is your video card.
6. if you don't find that there is any other problem you can detect, there must be problems within your computer monitor screen, otherwise It is advisable to go to your laptop service center and get the laptop checked. If you find that your laptop screen is still in warranty period and you find problems of flickering, it is best to get it changed.
Rgds
Dec 29, 2010 | Acer Extensa 4220-2148 Notebook
MY tomtom 720 screen flickers on and off but the image is still there but very faint can hardly see it, what could it be?
the problem is with the screen of the monitor of Ur desktop, can see the image as the image is always there in the monitor for some time the problem is with the circuit of the screen kindly take to to service centre of the respictive brand of the product
Dec 16, 2010 | Computers & Internet
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
Monitor flickers and faint bands scroll down the
could be fixed by ajdusting the refresh rate....
you could try this (xp pro sp2)
please rate if useful, good luck
Open Display in Control Panel.
On the Settings tab, click Advanced.
On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Oct 27, 2009 | HP w1907 LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Blank screen
Look very closely at the screen when its on, see if you can see a faint image in which case the ccfl tube in the screen will be dead. Also try the laptop on an external monitor.
Otherwise if you know what your doing, remove the battery, hard drive, optical drive, all but one stick of ram, modem/wireless card and try again. There is a small chance it will be the cpu or motherboard.
Jun 16, 2009 | Averatec 3200 Notebook
Color changes and flickers
To prove which Card or monitor are you in the position of either A- getting hold of another monitor or B Another computer connected to troublesome monitor Either way will establish which is the troublesome one. Then come back
May 08, 2007 | HP A4033A 20 in. CRT Monitor
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Averatec 3150H Notebook Logo
163 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
