Question about Sport & Outdoor - Others
Replacing solenoid relay
I have a 2000 big bear 400 2wd and the person that had the four wheeler before me looks like rewired the wires were you connect the solenoid. I need to know what that hook up looked like
    New Friend:
  • 41 Answers
Hello the red wire from battery goes to solenoid with the nut on it. And the other side with the nut goes to the starter motor. Sometimes there will be a B for + and a M for starter motor on the solenoid. On the + side of solenoid front of the + cable from battery a blue/black wire will go there. and the other side of solenoid will be a blue/white wire. I hope this helps
Posted on Nov 25, 2008
My 1999 yahama big bear 4- wheeler wont fire, replaced all electric parts 4 cdi boxes and still wont fire can u help
are you getting anything at all?.....you could check your ground wire(s) to make sure they have good contact on the bare frame metal
Aug 30, 2017 | Yamaha 2005 Big Bear 400 4x4
Solenoid wiring diagram
If you have a relay to the starter solenoid then red one from the battery then red from the relay to the starter solenoid. The starter solenoid earth wire goes into the starter housing for the brushes if not then the red wire from the battery goes direct to the starter solenoid big terminal. The other big terminal will already got inside the housing. That takes care of the really heavy wires . The small wire goes to the little terminal between the big terminals.
Jul 27, 2014 | 2000 Ford Expedition
Yamaha Big Bear will not crank and start. replaced solenoid, battery, cleaned carb ... new plug, traced all wires. help!
Smack the starter with a hammer or a wrench if the starter isn't turning over then it's bad if it does crank and won't start your CDI may be bad you've all ready replaced the little stuff sounds like it your starter is bad hope it not CD I if it is replace the stator as well and buy them on ebay it will save you a ton of money
Apr 30, 2013 | RTO 200cc Full Size Four Wheeler ATV
How to wire a coil on a 4 wheeler
1 thin wire in, one big fat wire to the spark plug. its not rocket science.
Mar 09, 2010 | RTO 200cc Full Size Four Wheeler ATV
When I push the starter button the solenoid clicks,starter does nothing.if I cross the 2 threaded bolts that extend out from the solenoid the starter engages? I just replaced the solenoid and at first it...
Just because it's new, doesn't mean it works.
This is why cars get recalled.
The iron-clan test of a non-working solenoid is to cross the relay terminals. If you do and it starts.. it's bad.
Take it back. you purchased a dud. It happens.
Jan 31, 2010 | RTO 200cc Full Size Four Wheeler ATV
Is the stator on a 2001 big bear 400 yamaha four wheeler four wheel drive supposed to have oil in it
Hi, yes I think it should, quite a few 4 stroke engines do, hope this helps :)
Jan 11, 2010 | 2001 Yamaha FZS 400 Fazer
Replaced the bearings both motors and have
searched for and found my wiring sketch but thankyou for asking
Dec 07, 2009 | Vacuums
Sport & Outdoor - Others Logo
273 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
