Question about Vehicle Parts & Accessories
Central locking on citroen xsara 2003
Hi. when i try to lock my car with the key or remote it locks then unlocks strait away as if one of the door are still open, but they are all shut. any idears
regards Larry
  • 3 more comments
  • Anonymous Jan 18, 2009
    same problem... lock with key...walk away and it unlocks... help :(
  • matt_the_man Jan 21, 2009
    At the moment i have to lock all the doors individually and unplug the battery before i leave it anywhere, as even if i lock them all individually and exit the car out a back door the boot is still unlocked and it unlocks itself a few minutes later anyway!
  • gthomas886 Jan 24, 2009
    my car locks then unlocks and the drivers side door can only be opened from the inside
  • Anonymous Feb 01, 2009
    Lock - unlocks lock-unlocks lock - unlocks wtf... :-(
  • grahampettma
    grahampettma Mar 10, 2012
    I had the same problem with my Xsara. There is a thin brown wire in the loom between the drivers door and the body which was broken. soldered it back together and the central locking worked again. you have to check carefully as the break will probably show as a small crack in the covering on the wire
We have this problem too - can only lock the doors by shutting front doors - climb into the car via the back doors - lock front doors from inside and then manually lock back door. Boot is difficult to lock - takes about 3 or 4 attempts to lock it. Driving me mad!! Have been told it is probably worn or broken wires in the flexi hose in the door hinge. I may have to take it to the garage to get repaired.
Posted on Mar 08, 2009
  • 88 Answers
It sounds to me as it is a mechanical problem with one of the locks.make sure the doors are closed properly also when locking car.best of luck.
Posted on Oct 18, 2008
My citroen c3 . 2003 the door lock won't work and my battery has died how do I gt into the car to open the bonnet or can I go underneath the car to release bonnet catch
You should be able to open the door manually with the key and you may have to turn it twice. Also try unlocking it whilst at the same time pulling on the door handle to the opening position or pulling the door handle to the opening position and then working the lock to open it manually. One way or the other it is designed to be opened manually with the key when there is a power failure with the power operated central locking not then operable.
Mar 19, 2016 | Citroen Cars & Trucks
How unlock child safety lock 2006 Citroen Xsara Picasso sx 1.6 8
Open the door from the outside and on the edge of the door there should be a red button with a slot for the tip of the key near the lock, turn this and this will de-activate the child lock on this door. Do this to the other door and the child lock will also be de-activated, to engage the child lock do the reverse of the above.
This is only on the back doors ok.
Oct 20, 2014 | 2006 Citroen Xsara Kombi
Driver door lock will not lock car door
No you need to replace the driver door lock.
Jun 27, 2014 | 2001 Citroen Xsara Picasso
Citroen xsara picasso 2005 tailgate keeps unlocking
lock catch is dirty. clean it with brake cleaner and then spay wd40
Jul 07, 2013 | 2001 Citroen Xsara Picasso
Need a central locking diagram for a citroen xsara xs picasso
Just do it today, in driver's side door, wires from manual keylock door switch, white wire-lock, green wire-unlock, whitegreen-ground, system is negative trigger on both wires (white-green), your black box for remote control should be configured for "Negative control signal". +12v from window electric motor (xara picasso 1.8 16v 2002' Bosnia)
Jun 04, 2012 | Citroen Xsara Cars & Trucks
Mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
Jun 11, 2010 | 2003 Volkswagen Golf
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
Vehicle Parts & Accessories Logo
1,183 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
