Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Timer for pre-set does not work
I can turn it on manually - but cannot use the timer - all the functions work as far as programing but in the morning no coffee until I hit manual.
  • graver5 Dec 27, 2008
    Program and clock are set properly to AM/PM but will not turn on automatically. Works fine otherwise.
    My timer does not work either. Time is set properly. Otherwise works fine but only manually
  • 8,596 Answers
Double-check AM vs PM on the timer programming set time.
Posted on Dec 17, 2008
How do I set my noma timer model 052-8873-0/49887.
Timer not identified.
According to google search052-8873-0 is fixya invention or older timer pre-internet
Following links will have same or similar timer
Water Heater Timers Save Money
Nov 19, 2014 | Hardware & Accessories
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
New intermatic timer installed. I can turn on manually and it will turn off at designated time but will not prgress to turn on automatically.
If display shows, and timer turns lights on-off with manual override, then timer is wired correctly, and battery is good.
If timer will not turn ON at scheduled time, but turns OFF correctly, then best suspect is the programming.
Open following link for ST01C programming steps.
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF, etc
Review your schedule: Press Mode button until PGM starts flashing, and then press ON-OFF button until 01 starts flashing.
If Program1 cannot be set for some reason, then set your ON schedule on Program3 and ignore Program1. The timer does not mind if you have OFF set on Program2 and ON set on Program3 or Program5 or Program7 etc.
If you have multiple programs, for example different ON-OFF times for each day, then check for scheduling conflicts that will cause timer not to function as expected.
If timer is defective, contact seller about 1-year warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
You want to control each light with different programming?
Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
You need a two-channel timer so each light can come on at different times.
Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
I have a ge timer 15132 and it is wired up properly feed to screw 1 and 2 , jumper from hot to com, load to no contact and the neutral tied with the other from the feed, all the time are set proper and the...
I have tested this timer.
GE 15132 timer can be wired muliple ways to accommodate different voltages and many different timing needs.
1) First thing is you must set dip switches BEFORE applying power.
Timer arrives pre-set for 277Volts.
For 120V, set all 4 dip switches to the left, or ON.
2) Otherwise your wiring sounds correct.
Hot black wire to far left 'clock' terminal.
Neutral white wire to next 'clock' terminal.
Jumper from Hot terminal to COM terminal.
Black Load wire on NO terminal.
White Load wire to same 'clock' terminal as Neutral
3) Possible solution:
Move wires to COM2 and NO2 and see if that relay is working.
4) Make sure your programming does not have conflicts.
See if manual override is working.
Test for voltage across 'clock' terminals
Move manual override and watch if relay clicks open-closed.
Check that Load is operable by moving NO wire to COM terminal.
5) If timer is not functioning, exchange at Home Depot.
You can switch out mechanism without replacing box.
Mechanism is held with hex screws.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 22, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Installed several GE smart digital timers around the house: for lights over garage, front door, court yard. They are model 15086. The units work in timer mode as desired. I would think...
15086 timer:
Pressing door will override timer setting and manually turn switch ON-OFF.
Press door or open timer door, and press any of 4 buttons located in corners.
You know information posted so far:
However, you are moving the small switch from Timer to OFF.
And when switch is OFF, the override does not work because circuit is OFF.
You want a timer that can switch programming OFF, and not switch circuit OFF, so that device toggles between timer and ordinary switch.
Looking at timers on the market today, I cannot think of any in-wall programmable or box timer that does what you want. Each has manual override that reverses timer function, but when you set timer to OFF, the circuit is OFF.
Plug-in-type timers have override button that turns programming off, and then you can operate table lamp normally with the lamp switch. But in that case, the lamp has separate switch that operates outside of timer functions.
GE 15070 24-hour mechanical timer could do what you want:
In this specific case, when you wanted to operate timer like a light switch, you would move all the pins inward, and then use the on-off switch. The problem with this idea is the pins are tiny, and you need very good eyes or a light-source and small tool to continually adjust pins.
See GE timers and manuals:
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | UPM Programmable Wall Switch Timer
Need to know how to program merry brite digital indoor timer?
Merry Bright digital looks same as GE 15057 and Westek TE55WHB timers
To identify your timer see following two links:
Add a comment if this is not your timer.
Here is Westek TE55WHB manual.
Read manual for full information.
Here are instructions taken from manual.
To set current time:
Hold down CLK button and then push day hour and min button until current time shows.
To program:
Press PRG button until 1 and ON display.
Press day hour and min button to set program1 ON
Press PRG button until 1 and OFF display.
Press day hour and min button to set program1 OFF
Press PRG button until 2 and ON display.
Repeat steps to set more programs.
Set up to 7 programs
Programs repeat each 24 hours
When finished, press CLK button and current time displays.
To operate timer: press MODE button.
AUTO to run timer functions.
RDM and timer turns on-off at random times.
Manual to override timer functions.
Dec 22, 2010 | Garden
I have a GE Heavy Duty Digital Timer product # 15117. It also says it is a Jasco Product. I am having a problem getting the clock function to work. I can set the time yet I do know see where there is an...
My auto function on my GE outdoor timer didn't work orginally. So, I programmed the "on" time to be 5 minutes from the current time (10:15 p.m.), and the "off" time to be the time I wanted (10:30 p.m.). Then I put it on automatic and waited for 10:15 p.m. to arrive. It turned on. Then, I set the "on" time to 5:30 p.m. and it works fine now. Apparently, it has to cycle through the "on" time in order to activate the auto function.
Dec 10, 2010 | Garden
I programmed the timer as instructed but when the time to turn on came it didn't turn on. I changed the mode to "on" & it turned on but I don't think it will turn off automatically. What...
You posted under Woods outdoor 2-outlet timer 59403:
Lets run through trouble spots others have with programmable timers:
Add a comment any time and I will help.
What we know for sure:
-Battery is working because display shows.
-Manual override works, so basic electricity is OK and light is OK
-Common programming problems:
-You set current time and it shows in display > if current time is not set or does not advance with passing time, then timer does not know when to turn on-and-off. Double check display for current day, hour, and minute.
-Each event has ON time and OFF time. So you set event1 ON and then set event1 OFF. For example some people set ON time and don't realize each ON needs corresponding OFF, or can't find how to set OFF. Trick is making sure timer display matches fig3 and fig4 shown in manual. Press PROG button until display shows 1ON for event1 ON and then press PROG button until display shows 1OFF for event1 OFF.
-To review programs and double-check, press PROG button repeatedly to scroll through programming. Check for ON and OFF days, and for overlapping on-off commands.
-Event1 ON and event1 OFF should be set for same day(s). For example event1 ON is set for Tuesday but event1 OFF is set for All-days (instead of Tuesday) will conflict and timer will not function.
-Conflicts in programming will cause problems. Conflict example: Event1 says ON 7pm OFF 9pm Tues, but event2 says opposite.
-Make schedule of on-off times before programming to avoid conflicts.
Setting Mode:
MODE is manual override button: press it to set Automatic, ON-OFF override, or Random
Press MODE button until RDN displays in upper left corner, and then press MODE one more time to enter AUTOMATIC >>> you want automatic for programming functions.
Circuit analyzer: If above items check out 100%, and timer still doesn't work, plug timer to indoor plug on another circuit (not on outdoor plug). This will check if outdoor plug has electrical problem interfering with electronics inside timer. Buy cheap plug-in circuit analyzer from Home Depot electric department and double-check circuits.
59403 manual:
Nov 27, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
159 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
