If you only want to transfer your pictures from your camera to your computer, then you can do it by plugging in the USB cable from the camera to the computer and opening the drive letter associated to the camera thru windows explorer. Click on the drive and it will show you the list of folders on your camera that contains the pictures. You just need to click and drag the pictures to your computer's local drive.
If you need further assistance please let me know.
Probably will have to download them thru usb port to computer if they are there. I found it best to download it thru the usb when possible rather than handle and risk damaging the card, just a little static can ruin it.
Hello my friend,
Here two ways to transfer pictures from your internal memory into your computer:
1- If you have also an external memory in your camera, you can move the pictures from the internal memory into the external memory from the camera menu. then you take out the external memory and you insert it to your laptop if it has a memory slot, otherwise you will need to buy an all-in-one memory cards reader, it's very cheap and it's the easy way.
2- if you don't have an external memory and you have the USB cable, you can connect the camera directly to your computer. but you will need to have also the CD ans install the camera software in your computer and then you can browse your internal memory directly from the computer and then download them.
Best Regards,
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
You cannot send pictures directly from the camera. The pictures have to be uploaded to your computer first. Your camera doesnt have a "built in" internet connection. The easy share button is for send pictures to your friends AFTER they are loaded onto your computer.
maybe if you reset the cam and card, by formatting it using the PC rather than the Camera, save what pix u can then format, to format, goto my computer right click camera drive, usually F:\ press format, do a full format, dissconnect from PC then make sure u leave power on and format thru the camera, dont know if its possible top save pix but this shud fix the whole card issue
