Question about Minolta Office Equipment & Supplies
Dialta di620, error codes c-0F34 AND C-OF33 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,168 Answers
Replace the developer if you can find it two bags are required. if that does not work mite be the sensors . when was last time a PM was done on the machine Drum replaced cleaning blade replaced? Remove the old developer then replace it then run F8 in service mode clear developer counter also.
Starter or Developer 8935-912 two bags
Drum 1155029101
cleaning blade 1074-090401
try percission roller company for the parts
Posted on Dec 28, 2014
Minolta dialta di620 error 14ao hilp me
Exposure lamp header failure. The exposure lamp is the bright light under the big sheet of glass the comes on to make a copy. Raise the Document feeder and press the start button does the bright ligt come on.
To reset open the front door in the upper left is a small access panel open press the trouble reset. if the code comes back replace the exposure board and lamp
try this place as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 09, 2015 | Minolta DiALTA Di620 All-In-One Laser...
Dialta 620 error code c-0120
Directly below the drum is a assy. that has two very fine wires in side of it that have several thousand volts applied to them during the copy/print process. and what might have happen is that they broke or the end assy. blocks that hold them have begun to break down due to old age check the wires replace them if required replace the end blocks or get whole new assy.
Oct 04, 2013 | Minolta DiALTA Di620 All-In-One Laser...
Di620 printer setup
at best you need windows 95,ME or NT try XP. legacy Minolta machine, Minolta now is Konica Minolta try this web site Self Help Product Support Konica Minolta Business Solutions Inc
Jun 13, 2012 | Minolta DiALTA Di620 All-In-One Laser...
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
Code error c-14F2
Image processing board or the control board for the scanner section. Good luck they make them a very, very old legacy Minolta machine.
Nov 26, 2010 | Minolta DiALTA Di620 All-In-One Laser...
Error code C-004A
C004A Exposure fan problem
You will have to take this printer in for repair. Unless you can remedy yourself?
Aug 03, 2010 | Minolta DiALTA Di620 All-In-One Laser...
Error message in di620
my copier says toner colection box is full what can i do
Mar 16, 2009 | Minolta DiALTA Di620 All-In-One Laser...
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
251 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
