Question about Lang Manufacturing ECO-8M Electric Oven
Lang ECO-8M Convection Oven
The internal circuit breaker is tripping before I turn the power switch on. The incoming voltage is within tolerance. The fuses are not blown. When I disconnect one side of the transformer from the fuse the breaker does not trip. Naturally I assumed the transformer was bad, but when I read the resistance I got 65 ohms on the high side and 10 ohms on the low. Any ideas on what I should check?
2 Suggested Answers
patsrr315
  • 16 Answers
SOURCE: Lang Platinum series convection oven
make sure fan blades are clear of crud build up
Posted on Jun 07, 2010
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Circuit braker trips as soon as i switch oven on
It is possible there is a heavy short on the oven and so the circuit breaker cuts off the supply when the oven is switched ON.
You will need to disconnect the coils to the ovens one by one till it is confirmed of the shorted coils. A test of the coil also will indicate the fault. If this is a ELCB then the ground leak within the oven /poor ground connection of the outlet can also cause the issue. make sure there is no damping in the connections of the power to leak and trip the circuit.
Jun 17, 2011 | Smeg S1100MFX5 Electric Single Oven
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
The display panel is blank, and none of the buttons work. It had been working earlier in the day, but is no longer functioning. Is there a breaker button?
Hi, Check to see if there are any lights working, such as the ones that come on when you open the oven doors. If there is absolutely no power going to the unit, check the household circuit breaker panel that services the oven.
An oven works at 240 volts so the circuit breaker for it will be a double breaker, similar to the ones
electric water heaters or air conditioning units. It may have tripped. If it is tripped, then
the lever connecting the two sides of the breaker will not line up with other breaker switches in the
breaker panel. If that is the case, shut down the breaker completely and then after about 10 seconds,
turn it back on. If it will not stay on, there is an electrical problem in the circuit going to the oven or the oven itself. Hope this helps. Let me know if your need more help.
Best,
Mark
Dec 30, 2010 | KitchenAid Architect ® II KEBS208S...
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Sep 12, 2009 | GE Ovens
Internal breaker trips
You will need to get an ammeter to see how many amps are being drawn by the motor. You can purchase an inexpensive meter at home depot or Radio Shack, The meter should be clamped around one of the wires from the motor. If the amps are more than the internal breaker, the motor is bad (even a new motor) if the amps are lower than the internal breaker, the breaker itself is your problem. You should also verify that you have the proper voltage motor and input to oven. Hope this helps
May 01, 2009 | Moffat MOF-E35E85HLD8 Turbofan Convection...
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Faulty switch?
thats a direct short somewhere within the oven. it happens whenoyu turn the oven on???, def check for a shorted wire, wire hitting hte cabinet of unit.
Mar 22, 2008 | Magic Chef 9122 Gas Single Oven
Lang Manufacturing ECO-8M Electric Oven Logo
108 people viewed this question
Top Lang Manufacturing Ovens Experts
Dennis Boxerman
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Lang Manufacturing Oven Expert? Answer questions, earn points and help others
