I would like to know how to print different photo sizes using a canon camera with pictbridge. This printer does not have access to a computer.
What model camera are you using? Normally, once connected, unless the camera has settings for print size and other options the printer will print whatever the default size is.
Here is a link for the Direct Print guide if you don't already have it:
Canon Direct Print Guide
It's not unusual for certain features to be unavailable when mixing different brands. Print size may be one of them in this combination.
The camera compares its PictBridge functions to the functions of the printer. The camera then displays the supported functions on menus on the LCD screen or in the viewfinder.
PictBridge print options
Once a PictBridge digital camera is connected to a compliant printer, print options appear on the camera LCD. The camera menu system is used to make settings such as print size, layout, media type and date.
You can print a single image displayed on the camera, print two or more images or print all images on the memory card. You can print part of an image by first cropping it within the camera and even create index prints, also known as contact sheets.
Print sizes and PictBridge
Not all PictBridge digital cameras let you select all available prints sizes, such as 13×19? if you have a wide format printer. If the printer has a memory card slot, use it and larger size prints should be available.
Is your device PictBridge compatible?
To find out if a camera or printer is PictBridge compatible, look for the PictBridge logo on the packaging or check the manual for specifications. If still unsure, call the manufacturer!
Hi Techosavy
The camera is a Canon powershot A560
It doesnt come up with any printsize options, according to the hp website it should be possible but not really sure?
Please help! Thanks for your help and time
Andywadders
Thanks again Technosavy, I will read through the direct print guide and let you know how we get on.
Andywadders
