Question about Garden
Weed trimmer primer bulb does not pump full, and trimmer will run out of gas I have a Mcculloch edge trimmer. I replaced the two fuel lines but the fuel Primer/Bulb does not fill. There seems to be be an air bubble that does not want to feed through. Where the fuel lines goes into the holes in the tank, does the intake and overflow fuel lines both be submerged under the fuel level, or is there a possibility that there are an air leak somewhere?
  • 163 Answers
No, the overflow line does not need to be submerged. first make sure that the hose connections are tight and the "O" ring or gasket inside the gas cap is not damaged or missing. when replacing both lines at once, its easy to get them mixed up, so make sure they're not. remove the carbuerator and inspect the gasket; it should be soft and flexible, if its hard or brittle it needs replaced. it doesn't take much to clog it, so spray carb cleaner, available at local auto parts store, inside the fuel rails and blow out with compressed air. there might also be a pin hole or bad seal in the primer bulb and need to be replaced.
Posted on Nov 28, 2008
Take the bottom off the carb (single silver screw). Inside you should see a small screen filter. This is rigid but can be pried out.
Remove and replace it, or clean it with carb cleaner. This filter clogs very easily, but must be totally clean in order for fuel to flow through. (This solved my fuel flow problem after having tried everything else ! )
Posted on Aug 09, 2009
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Sep 02, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
533 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
