Question about Acer Aspire 5610 Notebook
Acer 5620 boot up problem
My laptop wont boot up. When i press the power button it seems as though the laptop is going to boot up, but then another green light starts flashing, then the laptop turns itself off.
I was thinking it was in some kind of sleep mode but i cant get it out of it. ive tried removing the battery etc but it doesnt work!
  • Acer Master
  • 1,250 Answers
Check whether your hard disk is detecting on bios or not, if detecting then also check cooling fan is working or not, also check your adapter
Posted on Oct 16, 2008
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need acer extensa 5630ez wont turn on.i tried charging it for still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] -
Apr 27, 2011
More results from
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ... > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 no signal and the power on and off three times and go off
I understand from your short ( very short ) words that the laptop won't start.., if so :
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 14, 2011 | Acer Extensa 5620-4677 Notebook
MY 5620 series laptop is suddenly wont power on, what is possible reason of this?does motherboard failed to function?
If something HASN'T died, you can unplug the power and remove the battery. Plug it all back in 10 seconds later, and it should boot as normal.
May 26, 2010 | Acer Extensa 5620 Notebook PC
Acer 5620 pressing f8 at start wont load bios either
F8 is usually reserved for Windows Safe Mode. BIOS settings are usually found with by pressing ESC, Delete, or F2 on most system. Some times I run my finger along the entire row of function keys like a piano if it isn't specified which key works during boot up.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Acer extensa 5620 p[owers up to boot stops then reboots three times then stops blank screen through out procedure changed hard drive to no effect.?
You boot files could be damaged. Try booting up in Safe mode. To boot in to Safe Mode. Press the F8 key while booting up and you will get a list of booting options. Choose the Safe mode. If you are able to boot up in Safe mode, then the next normal boot should solve the issue.
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
Acer 5620 will boot up then resets to initial
Well it seems that the operating system of your laptop is crouped due to some region like may be have virus in the laptop or due to not proper shutdown etc.....
you need to recover or reinstall the operating system using the boot-able CD of that operating system.
please let us know what operating system you are using, so we can help you in details.
Good Luck!!
Dec 22, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 it shutdown but stiil power remains on.
please install "Avast antivirus" after installing the antivirus, system want to restart then you must restart your sytem , then the system scan all drives for viruses at boot time,if any virus is found the system will want to delete it by pressing 2 and it will delete all viruses from your system, then you must repair your operating system with xp bootable CD , after repair you must install your system drivers......... and then your problem become solve
Jan 25, 2009 | Acer Extensa 4620 Notebook
Acer Aspire 5610 Notebook Logo
182 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
