Question about Hoover H130E Front Load Washer
Hw120m washer/drier no heat on drier clothes still wet
  • 1,031 Answers
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
window.google_render_ad();
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
hope this helps
Posted on Oct 16, 2008
  • Hoover Master
  • 19,396 Answers
Check if the dryer is heating, if it is not heating check the following There's no heat
  • Ginko
    Ginko Oct 16, 2008
    The clothes are wet after spinning
    When the clothes are wet at the end of a cycle, check these:
    Motor coupler
    Spin cycle
    Siphoning
    Water-inlet valve
    Motor coupler
    To
    test the motor coupler, re-start the washer in its spin cycle. Let the
    machine run for a minute, and then open the lid and notice whether the
    tub is spinning:
    • If it's spinning when you lift the lid, the coupler is fine.
    • If
      it isn't spinning--and your machine was produced by Whirlpool®--you may
      have a broken coupler. Many Whirlpool-made washers use a small,
      relatively inexpensive device called a motor coupling. This
      plastic-and-rubber component is mounted to the shaft of the motor on
      one side, and to the transmission on the other. Over time, the coupler
      wears out and fails. When that happens, you need to replace it
      completely.
    Spin cycle
    If
    the washer doesn't reach its proper spin speed, the clothes may be too
    wet at the end of a cycle. Check to be sure the load is properly
    balanced and run a spin cycle again. If the clothes are still wet, you
    may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),
    or a worn motor pulley or tub bearing. Replace the applicable
    component.
    Alternatively, there could be clothes caught
    between the inner and outer tubs. Read the "It spins but won't pump"
    section of the "It won't drain" section. Also, there could be other
    things that cause friction on the drive train. Seek the assistance of a
    qualified appliance repair technician.
    Siphoning
    If
    the water that pumps from the machine goes right back into the machine
    after the spin cycle, it may be because your washer is siphoning the
    water from a laundry tub with a slow drain, back into the washer. Try
    to improve the draining of the laundry tub. (Is there something stuck
    in the drain?) Also, be sure the drain hose doesn't reach more than
    about 4 inches into the laundry tub. If it does, cut off the excess.
    Water-inlet valve
    Water-inlet
    valves eventually fail. One problem that may develop with a water-inlet
    valve is that it can no longer completely shut off when the electricity
    is turned off to it. Then, the valve may leak and drip water into the
    clothes tub--you may notice that your washer has water in it when you
    haven't used it for a few days. To fix this, replace the valve. From Repairclinic
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
My Neff drier isnt drying my washing it is hot but the
Is the fan working? this blows air across the element which in turn cools the steam into water then pumps it out via pump,Hope this is of some help
Apr 13, 2010 | Neff V4380X0 Front Load Washer / Dryer
Drum turns and you feel some heat but does not dry clothes
check to make sure you have no lint buildup in the drier itself along with lint build up in the exhaust hose leading from the back of the drier. If there isn't proper exhaust from the lint filter to the outside of the house or apt. then the clothes will get hot but still be wet.
Hope this helped
Dave
Mar 02, 2010 | Frigidaire GLER331A Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Hoover H130E Front Load Washer Logo
206 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
