Question about Optoma HD72 Multimedia Projector
Sound from projector
I have an optoma hd 70x projector which is connected to a PS3 and a game chair. I also want to use it for freeview and need sound. What do i need for this and how would i connect it?
  • frikkajik Mar 25, 2009
    hi here i have a problem connecting my ps3 i have picture but no sound
  • 431 Answers
All you ned to do this is a Scart to Phono lead from any good elctrical store and follow the instructions in your projector manual and the freeview units manuel .. ... Reagrds vortash
Posted on May 10, 2009
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
Optoma 25hd air filter issues
Hi Cathy,
The replacement of the filter is something that needs to be done at a service center by a trained technician. If you are interested, feel free to send us a message: Projector Repair Bulb Replacement
Jan 16, 2014 | Optoma HD25-LV - HD 1080p 3D Home Theater...
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
I bought an Optoma HD 66 projector. Worked great for about 2 and half months, today I noticed a blob of discoloration in the top left corner. What happend, can i fix this?
My optoma es526 came with a 7year colour warenty,try ringing up optoma and send your projector to them or try replacing the colour wheel.
May 06, 2010 | Office Equipment & Supplies
Ps3 connection
connect using the old ps3 lead and put the yellow end into the tv, then connect the white and red leads to your gaming chair. On the ps3 menu go to sound settings and change the sound settings to Av the only way for it to work hope this helps
Dec 26, 2008 | Pyramat Sound Rocker Gaming Chair
Connecting x rocker chair to ps3
I HAVE THE SOLUTION for all ps3 and ps3 slim gamers with the x rocker chair. it took my 2 long hours of frustration but i finally figured out how to make it work with ps3 slim. okay, forget about the red and white audio output plugs, those aren't needed. (my tv has no audio output jacks so i had to find a different solution) find the cable with the green headphone plugs on both sides. plug one end into the tx box and the other into the headphone jack on your tv. make sure your sound settings on your ps3 are set normally so that the sound is coming out of the tv. turn on the tx box, turn up the chair volume (and volume on the tv) and there you have it. enjoy!
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Optoma HD72 Multimedia Projector Logo
181 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
