Question about MSI RC410M-L Motherboard
Graphics No graphics to monitor
  • 2 more comments
  • Alex Boyack Oct 16, 2008
    Monitor Model:- Philips 170C6
    RC410M mobo with on board graphics card
    Monitor power on (It works on other computers)
    No bleeping sounds
    All connections checked OK
    I am trying to find out if there is a slot to installanother graphics card and disable the on board one.
    Thanks for trying. I hope you can be of assistance.
    Alex
    I've cleaned and reinstalled both "installd memory" sticks. Is that what you meant. I'm not clear about the reference to the CPU.
    I need to know what is compatable and How to identify the AGP video card slot. (If I have one)
    Thanks for all your help. I learned a lot.
    New video adaptor seems to be the next step. I'll give it a try.
    Alex
    Brigadier General:
  • 3,614 Answers
For some additional info: i want to more about your device.
1. what is trhe model of your monitor.
2. are yoyu using a vga/pcia card or a built-in/on board graphics adapter.
3. did you your monitor has a power or the led has a light.
4. did you hear any beeping sound coming from your cpu.
5. did you check all the connection from the pc to the monitor was correct. & also the power and power cable,
let me know..
Posted on Oct 16, 2008
  • 1 more comment
  • micromaster
    micromaster Oct 16, 2008
    ok. did you have any idea how to locate / check inside your cpu unit..?
    follow this steps.
    1. there's a memory strip inside your cpu, its either 1 or 2 are installed there.
    2. remove each strip and try to wiped the bronze part on the strip.
    3. then put it back on again on your cpu. ( be sure it was properly fixed and fitted on the slot.
    4. try to power on again your pc.
    let me know.
  • micromaster
    you can try installing a AGP video card, once you have installed it in your PC it will automatically disabled your on board video...
  • micromaster
    the one with the blue circle is where you will place the new video card...
    this video adapter will work on your mobo.
    (click on the image to see the complete detail of each figure)
No picture in my monitor but the monitor is on
If monitor is on it could be (1. the screen cable is faulty .(2 then screen cable is not plugged in, or you have installed a graphics card and connected it to the on board and not the graphics card.If its connected to the motherboard or the graphics card and is not coming on then your graphics card or onboard is shot.If onboard is shot buy a graphics card and install it or replace graphics card.
Jan 04, 2014 | LG L192WS-BN Monitor
Black Monitor, (NO SIGNAL FOUND)
Start your computer with monitor attached to the onboard graphics poart,
go to bios,
search for graphics setting and change it to PCIE.
Exit while saving changes connect your cable to graphics card port.
This will solve ur problem.
Nov 25, 2012 | MSI N210-MD1G/D3
Non display for DELL GX 110PC Desktop
Either your monitor is bad or the video card inside the computer is bad. To isolate the problem try a different monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker. If the borrowed monitor works, then your original monitor is bad. If the Borrowed monitor does not work, then the video card inside your computer is bad.
May 11, 2012 | Dell OptiPlex GX110 PC Desktop
THe Emachines T6534 is not recognizing the monitor i have plugged in, thoguh the monitor is also emachines and i'm pretty sure it came with the computer
The problem could be with your Graphics card.
1) Try the monitor on another PC, is it good? If yes
2) Try removing and re-seating the graphics card.
3) If on board graphics and so no graphics card, try a PCI graphics card in one of the spare slots
Apr 06, 2011 | eMachines T6534 PC Desktop
New graphics card problems with my Presario SR5350F...
Make sure you plug in any auxiliary power cables are are required for the video card.
Is the card used. Has it ever shown signs of life?
Go into windows via integrated graphics and install the latest drivers.
After that I would go into your bios with integrated graphics and turn off intergrated graphics. Look around if there's like a setting that's like switch to PCIx graphics or something. After the restart try to use your monitor though your video card.
Apr 26, 2010 | HP Compaq Presario SR5350F Desktop PC...
We have Dell OptiplexGX745 smallform factor desktop computers that we need to run two monitors.
If your Dell Optiplex GX745 came with the ATI Radeon X1300 graphics card, that has One - DVI graphics port, and One - VGA graphics port, it's no problem.
This link shows an ATI Radeon X1300, and the two above mentioned graphics ports,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5550932&CatId=28
(Please scroll down to the larger photos for more detail.
The Radeon X1300 graphics card in your computer, is a Low Profile graphics card. It will not look exactly like the one shown.
Low Profile means shorter in height. Your graphics card is shorter in height, in order to fit in your SFF computer case. {Small Form Factor}
The longer white connector shown on the left side of the view, is a DVI port. (Technically it's a Dual DVI port)
The shorter blue connector shown on the right side of the view, is the VGA port.
1) If one of your monitors has a DVI connector plug, simply plug it into the DVI port.
If the other monitor also has a DVI connector plug, you will need an adapter to plug it into the VGA port.
2) If both of your monitors have a VGA connector plug, one will plug into the VGA port on the graphics card.
The other will need an adapter to plug into the DVI port, on the graphics card.
This link shows an adapter for connecting a monitor with a DVI connector, to the VGA port on a graphics card,
http://www.directron.com/dviadapter.html
The adapter to connect a monitor with a VGA connector, to a DVI port on the graphics card is opposite of this.
[ I have found them at Radio Shack.
This = Expensive! $14.99
Not advertising for Radio Shack, or the above website in the link]
NOTE*
Use care when selecting the adapter you need.
A monitor with a VGA cable connector has the Male pins.
Your adapter must have the VGA Female sockets.
The DVI side of the adapter must have the Male pins.
It goes into the Female socket holes on the graphics card.
Same with a monitor that has a DVI cable connector.
The adapter must have Female DVI socket holes.
The other side will have Male VGA pins.
If your ATI Radeon X1300 only has One - graphics port, I Do Not advise using a splitter.
This is an adapter cable that has a connector on one end, and splits into two cables.
The graphics quality will be poor.
If you have No graphics card the situation is worse. This is Onboard, or Integrated Graphics.
(OnBoard. On the motherboard)
Using a splitter cable will result in very poor graphics.
How to tell if your Optiplex GX745 only has Integrated Graphics?
Look at the back of the computer. Come down from the audio ports. (Green and Blue)
Look under the USB ports.
The Blue VGA port is the Integrated Graphics port.
If you have an ATI Radeon X1300 graphics card, you will see a blue VGA port in an adjacent slot, also.
(Your computer can have Integrated Graphics, and a graphics card.
You CANNOT use the Integrated Graphics port, and a graphics port on a graphics card, At The Same Time!
It will Not work)
Once the two monitors are attached.
1) Turn both monitors on.
2) Turn the computer on, let Windows load
3) After Windows has loaded, Right-click on any empty area of the desktop screen.
4) Go to the bottom of the drop down menu, and Left-click on Properties
5) There are tabs across the top. Left-click on the
Settings tab.
6) You will see two rectangular icons. These icons represent monitors.
The one on the left side with the white border around it, is your Primary monitor. The main monitor you have always had.
The grayed out icon on the right side represents a Secondary monitor. This is for the second monitor you plugged in.
Note how the two monitor icons are sitting.
Primary on the left, Secondary on the right.
This is how your monitors should be sitting.
If it is Not, left-click on the Secondary monitor icon. Hold the left mouse button down, and drag it over to the left.
Now scroll down this window with your eyes.
Under the resolution settings you will see -
Extend my Windows desktop onto this monitor
There is a square box to the left of it.
Left-click in the square box. Go below to the right, and left-click on Apply.
Now go to the left, and click on OK.
Your monitors will now both be showing your desktop screen.
[Note* When doing this procedure, you have clicked on the Secondary monitor icon. Clicking on the icon activates it]
When you open the internet, or have a program going.
Go to the right side of the screen to the blue border,
of the Primary monitor.
When the mouse cursor turns into a double-headed arrow, hold the left mouse button down, and drag the screen to the right.
(You will note that the mouse cursor changes quite easily. It has to be double-headed in order for this to work)
If this direction does not work, go to the left side of the screen, drag to the left.
(You have to drag in the direction your monitors are actually sitting, in relation to each other)
Need some clarification, or have further questions? Click on Comment.
Jan 14, 2010 | Intel computers9: P3 Computer Computer...
Monitors wont work
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Nov 13, 2008 | Gateway 310 S PC Desktop
Monitor won't work with new computer
The computer in question has two graphics cards in it. A GEForce 8400GS Graphics card and an onboard graphics card. It could be possible you are plugging the monitor cable into the wrong graphics card slot. The onboard graphics card slot may be a different color than the GEForce graphics card slot. Check the back of the computer to see if there is another spot to plug in the monitor.
Jul 13, 2008 | HP Pavilion dv6000z Notebook
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
ATI 256MB Radeon X550 Graphics card
r u using dvi or vga? does the monitor support dvi?
Nov 23, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
MSI RC410M-L Motherboard Logo
191 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
