Question about Seagate (ST3160827AS) 160 GB Hard Drive
Unable to install os
While installing the o.s in the middle of the installation it was not responding. then i did checkdisk in win recovery console then also i didn't success to install.
  • 158 Answers
If you having a propblem then change it, if you have a warranty of your hardisk then send it to service center or
connect that hardisk another computer and check it
Posted on Oct 16, 2008
How to uninstall window 8.1 and reinstall window 7?
Becouse you have installer the O.S. Windows 8 , go to right egde down or up > click on Setting > next > update and recovery > click on the second option { recovery } ,choose the option number two [ REMOVE EVERYTHING AND RE-INSTALLER WINDOWS } and now you can insert windows 7 disc, good luck.
Jul 31, 2014 | Medion Computers & Internet
I am having a toshiba portage m205 with win xp . Windows got crashed when I tried to load windows with recovery cd It doesnt recognize its recovery disk Pls help .
Hello
you can do one thing
with that your data will be saved.
try a bootable cd of win XP & install os again without formating C: Drive, just overwrite the os instalation in same drive.
maybe after that your problem will be solved
Thanks
Dec 30, 2010 | Toshiba Portege M205-S810 Tablet PC
OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Nov 13, 2010 | Computers & Internet
Hi, I am unable to use recovery wizard. I tried to re-install xp using win nt 32 manually,but could not do it, Now I can't shut down and I do not have back up cd. Could you please advice me how to...
If you have not removed all the partitions then you can boot with any OS disk and clear the c partition.After that take out the disk and press the recovery option.It should autometicaly partition the disk and reload the OS.
If you made any changes in the partition table then recovery could be done with the OS disk only.
Thanks.
Nov 25, 2009 | Sony VAIO PCG-K23 Notebook
Windows is resuming message
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
You can try this first before the XP repair :
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
Nov 04, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Unable to run and install Windows on my computer
try to format your hard disk first.. if you required any drivers.. try below link..
http://etech.maiila.com
May 20, 2009 | Microsoft Windows XP Professional SP2
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
No OS FOUND on my Pavilion a1600n (preinstalled Win XP) can I install Win XP Home Edition I bought. My recovery disk will not work.
boot with win xp setup disk.
set first boot devic as cd drive then insert win xp disk into it.
then follow wthe procedure .try to repair os win xp .if it is not found bye setup go to recovery console run this command: CHKDSK /r
then wait untill cmd probmpt.
ten u can repair win xp
Sep 15, 2008 | Computers & Internet
Xp hangs and pc stop responding during Xp installation.
Location off viruses is on SYSTEM RECOVERY and it can't be cleaned.It's just one way:
If u can change the PIN off HDD.It can do just programmer!
So my solution is just buy new hdd
Nov 23, 2007 | Computers & Internet
Acer laptop aspire 3000
You can try to reseat the HDD, that may resolve the issue. More than likely, there has been some damage to the HDD. Try running checkdisk to see if there are errors on the HDD.
If you need help, please let me know.
Ron-
Nov 11, 2007 | Acer Aspire 3000 Notebook
Seagate (ST3160827AS) 160 GB Hard Drive Logo
52 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
