RC410M How or where can I replace my on board graphic card??
  • 998 Answers
Usually "on board graphic card" reffers to an internal video graphics circuit intergrated into the motherboard. If your monitor's video cable plugs into a separate card, then you can replace the card. If there is no video card, then only option is to replace motherboard. Might be cheaper to buy new computer.
Posted on Oct 16, 2008
  • 22 Answers
First of all you should check if it your graphic card is either a PCI or AGP slot and check the AGP speed of either 4x or 8x check the manual if you have one, well the PCI slot is colored white and is longer than an AGP slot which is usually colored brown. Well, take extra care in removing the card be sure to unplug the the unit before unscrewing, be sure to ground yourself with a grounding strap or simply touching the metal part of the unit before proceeding. next you will need to unscrew the graphics card, the card in which the monitor is attached. Then you will need to gently lift the card slowly forward, in the case of the AGP card you will need to pop the white tab or a that little white lock on the side before proceeding. Then install the new card on either the AGP or PCI slot. gently aligh the notches of either the PCI or AGP Graphics card with two thumbs gently push down, you can feel it when its attached and in the case of the AGP slot dont forget the notch ok:)
PC screen problem: do I need a new graphics card (where to find?) or is it a driver or other problem?
I had that once but so long ago I can't exactly remember the cause.
I think I replaced the graphics card.
If my memory is correct I was sure it was the graphics card because my pc had on-board graphics that had been disabled because a graphics card had been fitted so I removed the card, transferred the video lead and restarted and it worked ok, just not as well. I replaced the graphics card and it was fine.
If your pc has on-board graphics that is currently being used, it probably means the motherboard is defunct, though fitting a graphics card in an expansion slot could render it usable once more.
Jul 25, 2016 | Graphics Computers & Internet
Do i need sm bus controller to detect my video card?
no your board will find them all plug in slot and on you go ok
Sep 24, 2013 | MSI RC410M-L Motherboard
Is there SATA Socket the msi rc410m-l ms7173?
Yes, it has four SATA socket (Port) i.e 4 Serial ATA Ports. You can take a look at the specification page... http://www.msi.com/product/mb/RC410M-F--L--FI--LA.html#/?div=Detail (RC410m series)
Or you can also take a look at the picture here: http://www.daliss.com/i-shop/komponenty/motherboards/ms-7173.jpg There are four SATA ports at the bottom of the picture..
Hope this helps..
Thanks for using FixYa.
Sep 17, 2013 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Do not know where video card is located
You have integrated or On-Board graphics which means your graphics controller is located on the mother board itself. fortunately you have a PCI-e expansion slot so you can buy a PCI-e graphics card to replace the on board graphics that is if your having graphics problems. or not if your just wanting to know where your graphics card or controller is located. Hope this helps
Jun 28, 2012 | eMachines ET1810-01 PC Desktop
MSI motherboard - RC410M MS7173. I had 1 memory card of 1GB - Ceon DD2 533 CL4 I bought the exact same one again, so I would have 2GBs. The board couldn't recognize the 2 cards now. The board suppose to...
could be defective board with broken contact try switch 1gb ram chip from one slot to other see if it work in both if not you got your problem also switch the testing 1gb ram chip with other 1gb chip
Mar 02, 2011 | MSI RC410M-L Motherboard
Cpu fan starting and then shuts off after 3 secs,
well for that you might jsut need to get a new board because if a chip had gone bad on a motherboard, you might as well get a new one.
Chips are not replaceable since they are not sottered on the mobo, they are imbedded
Apr 08, 2009 | MSI RC410M-L Motherboard
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Graphics
for some additional info: i want to more about your device.
1. what is trhe model of your monitor.
2. are yoyu using a vga/pcia card or a built-in/on board graphics adapter.
3. did you your monitor has a power or the led has a light.
4. did you hear any beeping sound coming from your cpu.
5. did you check all the connection from the pc to the monitor was correct. & also the power and power cable,
let me know..
Oct 16, 2008 | MSI RC410M-L Motherboard
Conflict between on board graphics and new graphic card
to get into BIOS tou have to press a key when computer starts and i just finding hard drives
key to press is either
1) del 2) f2 3) f10 most computers use these keys for BIOS
down the lower left hand corner od screen will be whar key to press
eg press del to enter BIOS
whenin BIOS you will have a list of pages to go open the one that has video in it use down key to get to it
on left hand of screen will tell you how to change it.when changed press esc key keep pressing esc until it come to do you want to save changes press y and enter computer will reboot
Remeber what you did incase you have to undo it
please post comment if this was helpful
Jul 27, 2008 | MSI RC410M-L Motherboard
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
