My philips freeline mt2100 pc wont sart up. I understand there may be certain things to do before it will. I'm sure its not a power supply issue.
2 Suggested Answers
  • 166 Answers
SOURCE: Phillips MT2100
I have seen a recent malware (short for malicious software) program that disables the cd-roms and prevents access to the c: drive by making registry changes. Go to download.com and download Malwarebytes and run it. It helped me get rid of this problem. This particular malware was pretty nasty as it prevented me from accessing the drives (no access through My Computer, Windows key + E (Windows Explorer) and access to it from the start menu was removed, and no USB drives either! I had admin rights and was still denied. The only way I could beat it was to boot into safemode with networking and download Malwarebytes. Try this first. Since you are using Peer to Peer software (Limewire) sharing you are a ripe target for viruses and malware.
Posted on Mar 20, 2009
My magnavox power button is blinking green and wont power on
sounds like a power supply issue very famous for bad power supply replacement power boards are available from www.tvcircuitboards.com
Mar 31, 2012 | Philips Magnavox 42MF521D/37 Television
I need to buy a internal hard drive for a Philips Freeline LS2200. Can you advise me if I need a 2.5 or 3.5 inches?
The Philips Freeline LS2200 uses a 320GB SATA Seagate, 3.5 inch width harddrive. (7200RPM)
The usual desktop sized harddrive.
Due to the low costs of SATA desktop harddrives, I would recommend at least a 500GB unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4499974&CatId=2459
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | Computers & Internet
My Philips LS1100 freeline desktop PC is too slow ???
u need to change graphic card first in something better !!!
what games u want to play, tell me and I'll tell u what u need exactly !
Your RAM ??? It can't be 2.6G, but that is place to start, ram must be same brand and value, compatible with Your motherboard !
Feb 24, 2010 | Computers & Internet
How to get Philips freeline laptop out of sleep mode
if you want to disable sleep mode then go to control panel switch to classic view then go to power option change the turn off monitor to never and check it .............
Dec 10, 2009 | Computers & Internet
Red blinking light, tv wont turn on
Most likely it is a power supply problem. The flashing red light is a code for the service tech to look at a certain circuit pathway on the power supply board.
You can usually find a Service Manual on the internet for less than $20. It will have everything on the red light codes and other valuable information about repairing your TV.
Aug 31, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Phillips MT2100
Mar 19, 2009 | Computers & Internet
Computer speakers are buzzing
Common humming sounds from computer sound systems stem from the follwing:
1) Interferance with other electrical componants / devices
Solution: EMF / Radiostatic shielding may provide the solution
2) Defective componants
solution: try the hardware in another PC, if it still hums, your board / plug-in compants may be defective.
3) Jack(s) - Headphones / speakers have loose connection
Make sure everything is plugged in securely, and your jacks have not been damaged, also make sure you are plugged into the correct ports.
4) Microphone boost / auxiliary settings
check your sound settings, disable any ports you aren't using. Line-in, Aux, CD-rom, Digital Input.. if they aren't being used, they may be creating "whte" static in the lines. Muting them, or disableing them in the sound settings for your device may provide the solution..
5) It has been known to happen that certain CPU / Case / Power supply fans emmit a sonic frequency through the speakers due to EMF expulsions from the electro-magnetic motor. This is rare, but is possible, Disable the case fan to determin if it's the culprit, swap power supply, or CPU fan to determin if they are the issue.
WARNING: Never run your PC without the CPU fan in full operation, Never run the PC without your Power Supplies fan in full operation: This can lead to DAMAGE to your PC.
On a personal note: My card has several different ports, make sure you are plugged into the correct port, and muting the Aux cleared the humming in my computer's sound system.
Jan 13, 2009 | Philips MMS 321 Computer Speakers
Philips freeline wireless keyboard and Mouse
Have you tried re-installing the software for the keyboard & mouse. It sounds like a driver is missing and the best way to solve it in most cases is to re-install the software from the disk that came with the Keyboard & Mouse. Hope that helps. Bud
Jan 05, 2009 | GE Wireless Optical Mouse
I have a philips freeline 1100 and have so many problems with it within 3 moths of purchas it has had a new hard drive ,fan, graphics board,ect; I now have the biggest problem with it it kept shuting down...
go to this link and read my blogs at bottom of page (my name is folkestoner) for information and help on Freeline LS1000s and LS1100s
http://news.digitaltrends.com/news-article/5985/philips-freeline-entertainment-pc-s
Oct 21, 2008 | Computers & Internet
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
