Question about LG Computers & Internet
LG FLATRON 915FT plus monitor OSD setting
Hi my monitor is 6 yrs old next month.
Windows XP, Evesham PC 2.4 Pentium 4 S-VGA.
The contrast and brightness are at 100%, but the picture is going. I'm checking on an LCD replacement, but can I tweak things at all?
The picture is blurred, greyed out and 'flat'.
Thnxs
Peter
Hodges' model
    New Friend:
  • 62 Answers
1. clean the G4 wire.
2. change the neck base.
3. adjust the focus preset in LOT .
Posted on Nov 26, 2008
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
When pc is booted up, monitor light goes from amber to green, but screen gets no display, until monitor is manually switched off and then back on. sometimes monitor green light will switch off...
pentium 4, you can get newer PC for $20 at Goodwill stores..
far newer.
why operate such old hardware, that being said.
no OS stated, we cant help unless you tell
what operating system there, Windows 2000,. NT, XP, Vista ? what?
what PC, the PC has service tag, HP tag, with a full model on the tag, telling again what you have allows the helper to help 10x better.
first off simple logic works here, its 2 pieces, 2 boxes.
one is monitor other is PC desktop (one is bad, for sure or cable)
the monitor is a relic of the past with a glass cathode RAY TUBE
in the year 2017, (fixed many back then/....) the carbondate is 2000
so its 17 years, old.
you can test in on any pc to see if it works but many CRT are not supported now on new machines,
any PC with a VIDEO jack called VGA.
warning, back in year 2000 the PnP system is fauilty or uses and old method not used now, so mixing old with new is not wise. or
not a valid test, and the sleep mode rules changed 2000
the "VESA" spec evolved.
the monitor has an OSD, if the OSD is dead , at any time
the Monitor is no good. it has push button on the front
called select. or menu,, On Screen Display, OSD,
it makes its own special menu there, even PC turned off.
monitor on.
with PC off
You can also plug in any working VGA monitor in to this unstated
Pentium box. and see if that BOX works in 5min work.
here is test 1,
turn on the monitor
and push the menu buttons on the the front of monitor
you must get this, or the MONITOR IS BAD.
sure power cord good. powered on, and power at the wall jack good.
i just googled you manual and read it, in 16sec flat.
and here is mr OSD,
75-hxtzib5ixwoiaxej5xouicye-3-0.jpgblack screens happen
here is all ways from sunday black screens of Deathh
http://pcdied.com/black-screen.html
"monitor green light will switch off "
out means lost power. or the MX75 intenal power supply is dead, or line power is dead. AC 120vac, lost power.
yell means sleep.
if out means blank, (not green/yellow)
that means the monitor is BAD.
time to get a new one.
walfart has em on sale.
for a whopping 40 bucks, the price of 2 potted plants.
https://www.walmart.com/ip/LA1751g-LCD-Monitor/155377466
Jun 03, 2017 | HP Pavilion MX75 17" CRT Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
OSD lock
On LG monitors (like the Flatron series) you have to press on the menu button for about 5-6 seconds)
it's in the instruction book.
Apr 23, 2008 | Computers & Internet
Best Display Setting for LG Flatron L1732S
Use these charts:
http://www.help4web.net/setup/mire.html
Theory behind it here:
http://www.poynton.com/notes/brightness_and_contrast/
Next time type into Google:
http://www.google.com/search?q=brightness+and+contrast+set+up+page
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Screen width keeps changing
This is a hardware problem. There's a high wattage resistor inside which normally gets quite hot. Eventually this resistor desolders itself due to heat and breaks the circuit. Any repair-shop can fix this by re-soldering mentioned resistor (it is easy to distinguish it by its brownish color) using a suitable solder or by replacing this resistor by a more powerful one. Another workaround is to change a video mode to, say, 1280x960 or 1152x864 (while in these modes, monitor circuit bypasses the said resistor).
Sep 10, 2006 | LG Flatron 915FT 19" CRT Monitor
Computers & Internet Logo
205 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
