Height is small in aiwa tv model tv-se2130k, and how to go in service mode.
  • 905 Answers
This is the conversion chip and vertical deflection chip that need to be replaced
service mode will only make the color alignment worse since the conversion chip is failing so it won't align properly
it will need that repair
Posted on Oct 16, 2008
How to restore facory settings for aiwa tv-a2119ke
To do a factory settings, you have to enter its service mode using its remote control. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 23, 2014 | Aiwa F2000 20" TV
Aiwa service mode
Press and hold Vol+ & Prog (-) key at the front panel of the TV, and plug on the Power. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Service mode entry, adjust and exit procedure to many brand TVs are given in detsil.
Oct 25, 2013 | Aiwa F2000 20" TV
IN AIWA 2119A MODEL SYSTEM IC TMP87CP38N MEMORY IC IS 24C08 AND SOUND IC IS 5277 AFTER CHANGING MEMORY IC SOUND IS COMMING FOR HALF AN HOUR AND AFTER IT STOPS BUT I NOTICED IN PICTURE IS VERY RED IN COLOUR...
Check this site for more details. It has details about entering service mode to many brand TVs. Check it. Hopes will help you. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 24, 2013 | Aiwa F2000 20" TV
How to enter service mode jvc tv? the problem is vertical hight
vertical height problem is in vertical IC side check the capacitor around it or re solder the section.
Jun 11, 2009 | Aiwa F2000 20" TV
Service mode of aiwa
Set the volume to a minimum, and simultaneously press the VOL-key 9 in the C / R. With the buttons 1-7 (or 1-8 in
some models) will select the different modes (sub-menu) to adjust. With VOL + / - values are adjusted. Press 8 (or 0 in some models) for
exit and save.
Apr 11, 2009 | Aiwa F2000 20" TV
Abnormal colour in aiwa tv ic noTA8759BN
You need to use Aiwa Service Remote to enter in service mode and adjust service data for red and Blue drive of CRT.
Do you have that remote and service data reference book of Aiwa tv ?
Oct 07, 2008 | Aiwa TV-S2011 20"
AIWA TV-A2119 PROBLEM: SOUND MENU NOT COMING
THE PROBLEM IS YOUR TV MODE HAS BEEN RECONFIGURED TO KE1 MODEL. SO YOU WILL NOT GET THE AUDIO MENU. THE SOLUTION IS, JUST BUY AN ANOTHER REMOTE RC-ZVT03 MODEL AND USE IT AS A TEST JIG REMOTE. OPEN THE COVER, YOU WILL SEE THE CONTROLLER IC BW7461-3T ( 16 PIN). ACTUALLY TO ENTER IN TO THE SERVICE MODE, WE HAVE TO PRESS THE "TEST" KEY. BUT THAT KEY IS NOT AVAILABLE IN THE REMOTE. SO SIMULATE THE 'TEST' KEY, JUST SHORT THE PIN NO 4 AND PIN NO 12 THROUGH A WIRE TO ENTER IN TO THE "SERVICE MODE". ONCE YOU PRESSED THE PIN 4&12, THE TV WILL ENTER IN TO THE "AGEING MODE". THEN PRESS "AV MODE" SWITCH IN THE ANOTHER REMOTE ( YOUR CASE ZVT13). A MENU WILL APPEAR TO SELECT THE MODE. PRESS NUMERIC KEY "3" (INDA-1) TO SELECT THE "AIWA TV-A2119KE" MODEL AND AGAIN PRESS "AV MODE" TO EXIT. AGAIN PRESS THE TEST KEY TO EXIT. RESTART YOUR TV. NOW YOUR PROBLEM SOVED. SINCE I ALSO FACED THE SAME PROBLEM, I GOT THIS SOLUTION (jp_ati).
Enjoy.
Dr. M. Jayaprakasan, Chennai
Mar 22, 2008 | Aiwa F2000 20" TV
Aiwa Tv sound menu is not coming
Aiwa A2119 21"TV
picture okay but no sound. service mode not function in remote control for rectification.How to get sound. My E mail ID is vattipl@yahoo.com
Dec 20, 2007 | Aiwa F2000 20" TV
Sound got off even sound menus in TV
It is really a memory problem try to access its service mode open the cover of its remote control so you can find an extra carbon switch inside which is not accessible if the remote control's cover is on.Another way is you can use an eeprom copier copy a known good aiwa ctv with the same model or parameters
Dec 26, 2006 | Aiwa TV-S2011 20"
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
