Question about Electrolux EW1000i Front Load Washer
Washing Machine does not drain all the water
My washer is a Hotpoint type. When empting the water it never finishes all the water. I have to throw the drain pipe on the floor to drain it dry.
  • tpinto300 Jan 20, 2009
    Are model number is VBXR1090 TOP LOADER WASHING MACHINE (HOT POINT) WATER WILL NOT DRAIN AND SPIN WHAT WILL BE THE PROBLEM
  • janines Feb 03, 2009
    I have a defy landromaid electro logic 1300, it is a toploader, i have to throw the pipe on the floor for the water to drain, the minute i lift it from the ground, the water won't drain. I am suspecting that it is a pressure problem...pls help. This problem defeats the purpose of being able to press start and going back to the machine when the load is completely done?
I have a ELECTROLUX MILLENNIUM SLIMLINE 1045F FULLY AUTOMATIC WASHING MACHINE. but it not works properly . can i get a mannual of it, because i lost it. it is not spin perfectly.
Posted on May 17, 2011
  • 750 Answers
Hello nsukiwa.
Welcome,
What is the model number?????????????????????
As I am working blindly for you!
Here are some ideas, until I have the model number.
You said, your washer is a Hotpoint type. When emptying the water it never finishes all the water. You have to throw the drain pipe on the floor to drain it dry.
I'm searching for answers to your problem with these questions!!
1. How long is the drain pipe and does it have to pump up higher than the machine to reach the drain?
As if it is in the basement and the drain pipe above it?
In this case you would need an external pump with some machines!
2. Is the water visible in the bottom of the machine when the load is done?
Or do you just detect some water left in the hose?
There usually is some water left in the hose, but it is not supposed to be visable in the machines tub.
3. I have a Speed Queen washer because this machine can pump the water up above the washer for 7 feet straight up to the drain above!
Most machines are not capable to do this!
I am awaiting your answersHuuum
Posted on Oct 16, 2008
Machine keeps filling of water
Usually a stuck solenoid valve. They can be taken apart and cleaned, but are easily replaced
Apr 28, 2012 | Electrolux EW1000i Front Load Washer
Washing machine has died and I dont know how to drain water from drum. HOTPOINT AQUARIUS EXTRA WMS38
hello get a bowl or bucket and position the drain hose a low as possible the water should drain out .as for the machine dying do you mean it's total dead if so check the fuse in the plug if ok then check the fuse inside the washer's power supply it's a glass type hope it helps
regards
shaun
Mar 26, 2011 | Hotpoint Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
My washing machin is not empting the whole water from the washer.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Washing Machines
Hotpoint wma30. Drum not draining water. Have
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint ultima df32 dishwasher
I have had this problem with a dishwasher before it was the pump. some of the water was empting but that was the weight of the water pushing it down! if its still under garentee get someone out, I dont know how expensive pumps are! it may be easier to look on ebay fot a new one!
Mar 29, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Wont finish washing cycle
suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
Jun 13, 2007 | Hotpoint Ultima WF860 Front Load Washer
Electrolux EW1000i Front Load Washer Logo
1,100 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
