Question about Nintendo DS Lite Console
Ds lite recasing
My son snapped the hing from his ds lite so i have bought a new casing for it.
I have pulled the old casing off but i can't work out how to separate the wiring from top case to bottom case
  • 4 Answers
When you take off the bottom case, and lift up the pcboard and lower touch screen, you'll see the ribbon cable connected there. It's held in place by a black connector that lifts up. Use something like your fingernail and life up on the black part until it releases (it shouldn't take too much pressure to lift it up. Once you do that, the cable pulls directly down and out.
Make SURE what when you put it all back together that you make sure to seat the ribbon cable back in there as far up as it will go. If you put it together and all you get is a bottom screen that flashes and it won't stay charging, I'm 99% sure that it'll be that connection isn't in there far enough.
I had to troubleshoot 2 of mine doing that recently. Found out that it was the cable that wasn't in there far enough. Once I put it in far enough, they worked like charms.
Posted on Oct 17, 2008
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
How can I replace my broken ds hinge
if its the weak hinge then strip down the bottom and leave the top pull out and replace the lock barrel
if its the snapped hinge then a new case a full strip down and rebuild if this is the fault i would watch some videos on youtube to learn how to strip down the ds thats how i started.
Jul 10, 2009 | Nintendo DS Lite Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
My hinge broke on nds
If you have a valid receipt nintendo will have to cover it under warranty. Provided it just snapped and is not broke because of bad handling.
Alternatively order a new case through eBay and just switch the old case with the new one.
Mar 31, 2009 | Nintendo DS Lite Console
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Josh Boyer
Jan 22, 2009 | Nintendo DS Lite Console
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
Broken Hinge
There are plenty of replacement cases available from a popular auction web site, if your proficient with a screwdriver and have a lot of patience then you should be OK. Take great care when refitting the top screen ribbon cable (and taking it apart in the first place), the WIFI arial cable is awfully fiddly as it needs to be threaded under the slot 1 cartridge mechanism and finally take great care refitting the bottom case as plenty of people have reported snapping the plastic part of the power switch when reassembling. I reckon a first attempt should take 1-2 hours so clear the dining room table and don't forget to buy a tri wing driver when you get your replacement case if you haven't already got one. Best of luck.
Mar 12, 2008 | Nintendo DS Lite Console
Nintendo ds - broken hinges
Try gripping them with a pair of long nose pliers and pulling them out. I'd advise a layer of cloth between plier teeth and rods, to stop them being gouged.
Nov 16, 2007 | Nintendo DS Lite Console
Nintendo ds hinge fix
Well, you can buy a hinge from a lot of places, but the wire that broke, you are going to have to try and fix the wire, get it connected again so that it will work. The only other solution is that you will have to send it in to get fixed.
Aug 08, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
