Question about HP iPAQ hw6515 Pocket PC
My HP 6515 is staying on a blank white screen after being turn on
After turning on the Pocket PC it loads up the starting screen,
"HP Pocket PC", then it just goes white and doesn't do anything else.
It charges up, but won't sync with the PC.
Any help??
regards
  • mintycake Oct 16, 2008
    Thanks a lot for the help, everything was backup so i went straight to the reset section. I wasn't reseting it in the correct way. Thanks again...
    Matthew
  • 4 Answers
Hello ,
Because the iPAQ is not booting up you wont be able to back up any data .
You can uninstall and re-install the Active Sync 4.5 from www.hp.com . Try synchronising . No go then try updating BIOS from the same link www.hp.com. If unable to do so please reply back with the iPAQ serial number (s/n) and product number (p/n).
Or first do a Soft Reset ( will not wipe off data ) by clicking on the link below :
http://www.howtoreset.com/IPAQPDAs/IPAQ6500
If still no go then go to Hard / Clean reset as in second part of teh above link. It will wipe off the entire data though.
Still no go , please refer to the nearest authorised service centre .
Regards ,
Puloma
Posted on Oct 16, 2008
I have a HP Ipaq 2490. It was working fine until a couple of days ago. First it wouldn't turn on, then finally it came on with a white screen. I did a hard reset and came back up. I went to install...
i just cried a river for you,
If I saw it in a garage sale for $1 id buy it and crush it so others
cant suffer like you, no really.
batteries inside both are gone, some are solder in too.
opps.
what good is this thing in 2017? tell me love to hear it.
buy used smart phone that has support.
why not ask HP, we are not.
ask them and hear load laughter,,or worse.
sorry but all ours are in the landfill making bad ground water.
https://h30434.www3.hp.com/
Oct 13, 2017 | HP iPAQ hx2790 Pocket PC
When i turn on my dell 110 mini the light goes from white to orange and stays there the screen doeset boot or anything
Remove battery, open the access panel on the bottom carefully remove the ram sticks. Put them safely on a piece of paper so that a static charge doesn't ruin them, also touch something metal before you try and remove. If your computer doesn't beep at all when you power it back on your CPU, GPU, or MB are bad. If it beeps then there is still hope.
Jun 10, 2011 | HP Mini 110-1037NR Netbook
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
My samsung SCH-i730 is stuck on the white loading screen
You may have to do a major reset on it. First remove and replace the battery and turn it on again. If that doesn't fix it, there is a tiny reset button on the bottom near the connector. You will need to push it in with a small point such as a paper clip wire.
Jan 03, 2009 | Samsung SCH-i730 Pocket PC
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
My screen is all white will not do anything else
Try to hard reset : Hold calendar, iTask and reset button like for 10 seconds.Warning! It earses every data on your PDA, but if you want to save it ... ;)
Apr 25, 2008 | HP iPAQ H5550 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
313 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
