FixYa.com
Tags:
Compaq SMART ARRAY 32MB 5300 Series Dual Channel Card Refurbished p/n 171383001  Storage Controller
Problem adding memory to a Compaq Presario 4172
By man1 - usenet poster
After adding an additional 32MB of memory to a Presario 4172 and rebooting
the machine, the system only sees an additional 8MB of memory. I installed
SDRAM PC83 32MB memory. Any ideas? Thanks for you help in advance.
Posted via CNET Help.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 28, 2006
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Mike in SoHeroVT
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
PC100 won't work in your 4786 (as you've found out). It will only
recognize true PC66 modules. Two web vendors, crucial.com and necx.com
allegedly carry the *correct* modules for the 4786.
However, their respective sites do not indicate the speed of those
modules. As such, I would recommend definitely calling them to verify
before ordering from either of those two vendors. I've found that they
both frequently state that they carry the *appropriate* modules for
Presarios that need PC66, only to find out that what they advertise is
actually PC100.
The only reliable vendor I've found that consistently shows the proper
memory for any given computer is K-byte, at: #.
Unfortunately, K-Byte does not sell directly. One has to look for K-byte
memory modules at stores such as Best Buy, etc.
Hope that helps...
KCGreek
Solution #3
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
I'm seeing the same problem trying to add two 32 Mb modules to a
Presario 4786. I have tried two different types of PC100 SDRAM.
I haven't been able to find true 66 or 83 Mhz chips.
Any other suggestions?
Thanks.
In article <>,
"radon2" <> wrote:
Sent via Deja.com #
Before you buy.
Solution #4
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
Solution #5
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
Solution #6
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Can you Help with these Storage Controllers problems?
Storage Controllers
Why won't my printer turn back...
After refilling the ink jets my... Answer This...
Storage Controllers
usb doesn't work
in the pannel control some usb... Answer This...
Storage Controllers
downloading data/photos
what kind of cd to use? Answer This...
Storage Controllers
Help me to install WinXP in a...
On trying to install WinXP in... Answer This...
Storage Controllers
i don't know
i don't know what sound driver... Answer This...
Repair Service
Find Storage Controller Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
