Question about Optics
Electrical fault on touch sensitive bed side lights
We have 2 bed side lamps fitted in each of 2 bedrooms. They are all of the touch sensitive switching type, fitted with conventional tungsten bulbs and provide a range of light intensity from low to medium to high.
They were all purchased from B&Q stores about 18 months ago and have been problem free until last month.
Recently they have dispalyed erratic behaviour of self illuminating and sequentially flashing without any human or physical contact. In one instance all four lamps were flashing simultaneously.
I suspected the cause to be an electricity power surge and fitted an inline power surge protector to the lamps. This device has been unsuccessful as the problem has occured again.
Another solution would be to fit in-line off/on switches but before doing that I would like to know if you have a better solution.
Thank you in anticipation
Ben
  • Anonymous Jan 17, 2009
    My touch sensitive bedside lights turn on by themselves, sometimes because a ceiling fan in an adjacent room has been switched.
    Any suggestions?
  • 3 Answers
Ok the problem you are experienceing is cause from supernatural forces dwelling in you abode. to solve this problem and remove any spirits you must...
Open all windows and doors.
Burn some sage in a shell and fan the sage smoke in all the corners of every room, hallway and closet.
Urge the spirts to leave peacefully and move on into the light.
Repeat in every room.
Close windows
You have now "smudged" your house and it is spiritually clean.
Posted on Oct 22, 2008
Just purchased bed. 5 lamps not lighting and 1 on canopy blew immediately after turning on. replaced lamps, replaced starters and holders. still have the same issue and have tried 2 more lamps in the one...
Have a trained technician to check the voltage going to the bed. If all bulbs / ballasts have same problem, this may be the problem. You may need a Buck/Booster.
Jul 04, 2011 | Wolff Sunvision Pro 24S Tanning Bed
I have just purchased three First Alert carbon monoxide alarms. My home has a basement and bedrooms on the first and second floors. My questions stem from the installation. Should the installation...
When I worked Electrical in a Hardware store we were told by Nighthawk and f\First Alert and we told our customers that you want the detectors 4-6 feet off the floor never near a water heater or furnace since this can cause false alarms. The CO will rise, so one on each floor should be enough near a central stair if possible. Other wise make sure at least one is in the bedroom.
Mar 01, 2011 | First Alert CO400 Battery Powered Carbon...
What does Multi-Gesture mean?
Multi-touch or multi-gesture, has been implemented in several different ways, depending on the size and type of interface. Both touchtables and touch walls project an image through acrylic or glass, and then back-light the image with LEDs. When a finger or an object touches the surface, causing the light to scatter, the reflection is caught with sensors or cameras that send the data to software which dictates response to the touch, depending on the type of reflection measured. Touch surfaces can also be made pressure-sensitive by the addition of a pressure-sensitive coating that flexes differently depending on how firmly it is pressed, altering the reflection.[2] Handheld technologies use a panel that carries an electrical charge. When a finger touches the screen, the touch disrupts the panel's electrical field. The disruption is registered and sent to the software, which then initiates a response to the gesture.[3]
Nov 28, 2010 | Computers & Internet
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
"Double" electrical switch has failed to function
In a standard 3-way switch arrangement you can turn the light on or off from each position.  If the wall switch has failed then only the bed switch will turn the light on/off.  Replace the wall switch with a new 3-way switch.
Jun 02, 2009 | Hubbell Electrical Products 2 Gang PVC...
Rear blinker light change 2001 ram1500
Hello
Welcome to FY
open the tale gate look at the side where the light is there is 2 screw that hold the light to the box
RD
Jan 10, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Our touch sensitive lamp no longer responds to touch
The sensors do not wear out as such, the fault probably is in the electronics and you should not attempt a repair unless you are suitably qualified as mains voltages are involved.
Nov 22, 2008 | Optics
Optics Logo
1,110 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
