Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-5316 will not print
I have purchased a brand new copier, i have removed all the transportation tapes and filled the cartridge with toner, but the unit will still not print copies, thay are always blank. i have tried to use the SPF tray with the same results, there are no alarms or codes displayed
  • 3 more comments
  • steventhomp Oct 16, 2008
    i have filled the toner using the bag supplied with the machine, and also checked the level with the control panel, it is saying there is 100%, i also cheked the cartridge and cant see any tape on it
    i followed the instructions that you gave and i am still having the same problem, there is no tape on the cartridge
    i have checked the cartridge and all tape has been removed and the shutter lock has been removed but still black copies ?????,
  • steventhomp Oct 17, 2008
    ok, very helpfull information, but i still have a question, where do you pour the carrier? is it on the roller?
    one other thing which is we have a problem with is that i am currently in very remote part of the desert and there is no way of getting a sharp engineer to carry out the adjustments to the machine
  • eseagu Oct 20, 2008
    Problem Solver:
  • 12 Answers
The toner cartridge comes in a box and fits into the developer unit. The developer unit is held in the machine by one 'phillips head' screw (usually blue in colour). The silver bag that came with the machine is not toner but actually called a carrier. The developer unit needs to be removed from the machine and the carrier poured into it. Thereafter you replace it in the machine, secure the screw and re-insert the toner cartridge.
However certain settings have to be made on the machine to set the basic parameters for the optimal useage of the machine and this is only done by authorised trained personnel.
I suggest you contact your closest Sharp dealer and ask them to do the necessary.
Regards
Gavin.
Posted on Oct 17, 2008
    Genius:
  • 1,605 Answers
Check the toner. it still have a tape covering the opening . look for a yelow or red tab at the either side of the cartidge.
good luck
if this answer your problem, please rate it
Posted on Oct 16, 2008
  • 3 more comments
  • Frank
    Frank Oct 16, 2008
    pleas follow th instruction that I give you.
    make sure to unlock the "lock release" and the tape is off.
    please rate the answer if the answer solved your problme.
  • Frank
    Frank Oct 16, 2008
    did you unlock the lock release on the side of the toner????
  • Frank
    Frank Oct 16, 2008
    you have to the printer "OFF LINE" if you are using it online for print.
  • Frank
    Frank Oct 17, 2008
    I can't really do any more troubleshooting without physically see the machine.
    if you can shoot some pictures of the machine opening where the toner goes, and the toner itslf will be helpful.
    Since there is no error code or any other indication of error, the best suggestion I have is to try another toner cartridge.
    good luck and let me know if that helps.
  • Frank
    Frank Oct 17, 2008
    please look at eh posting above by gavinsx.
    I totally foregotten about that.
How to solve an U2 error on sharp 5316
http://olsonbros.com/sharp/support/sim.html
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
Jul 27, 2014 | Sharp AR-5316 Laser Copier Black OEM Toner...
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can install developer in sharp copier AR-5316
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
My sharp copier ar 5316 has printed 0nly les than 1600 pages and now showing toner cartridge low, even les than 10%
please check the devoloper , if the quantity is lessthan the specified the same quantity will be filled with toner.
Oct 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
New Sharp AR-M162 won't print
Remove all the tape from the unit. there should be no tape, plastic, foam etc on the unit. After removing packing and tape reinstall and power cycle machine.
Hope that helps
TankMurdock
Apr 27, 2009 | Sharp AR-M162E Black and White Copier
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
237 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
