Question about Pioneer VSX-D511 Receiver
No Sub Woofer Pre out output
I have had a sub running for about four years and now there seems to have no output from the Sub Preout. I have tried a friends sub that know that works. All of the speakers still all work and there is nothing else wrong that i can tell with the amp. Please Help Me!!!!!
  • Craigo n Oct 16, 2008
    Thanks! Will try it right away
    If it ends up being the transistor?
    Would you have a circuit diagram for the preout board or where the transistor is located?
    Really appreciate it
  • 905 Answers
I've got the same model and the pre out transistor needs to be replaced,
sometimes you can get it to work by unplugging the reciever and the pre out
then plug in the reciever and plug the pre out in a couple of times or so untill it comes on
or unplug the amp from the wall then plug in the pre out , turn on the reciever wait for sounds to come on then plug in the amp.
if that don't do it the pre out transistor needs to be replaced
Posted on Oct 16, 2008
  • jason Oct 16, 2008
    it will look like this and be close ( connected) to the output
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
Preout section cannot ingage
If you are using a pre out to a sub woofer, you need to make sure that the sub has it's own power amp or it will not work. You also need to go into the user menu and tell the amp that you are using a powered sub. Otherwise it will not turn on the pre amp output
Jun 20, 2012 | Denon Avr1610 5.1-channel Home Theater...
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
JVC KD-PDR30 overheating
think the sub woofer my be drawing to much power try disconnecting the sub for a few days and see how it goes
May 21, 2009 | JVC KD-PDR30 CD Player
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Sub woofer
Is there a gain control on the sub? If not, are you using a receiver or pre/processor to control volume? There could be a level adjust or on/off control for the subwoofer output.
Jan 20, 2008 | Pioneer VSX-D511 Receiver
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Dec 24, 2007 | Pioneer VSX-D409
Pioneer VSX-D511 Receiver Logo
309 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
