Ethernet card Hey Temab, You just gave me a link to NVIDIA but seems to be specific to NVIDIA products My laptop is a Dell Latitude D410. What say you?
    Guru:
  • 257 Answers
Hello my friend thats ok.
Is just that the site i gave you, you can easily find what you are looking for from different maker and model of cards from different mnufacturer but if you cant go to this site of Dell ethernet card ok
You can use any ethernet card just depending on the slot it will go into ok
now take this site :
www.accessories.us.dell.com or
www.startech.com/category/parts/networking/network-cards/gigabit-adapters/list.aspx
MSRP Ethernet card - st1000bt32.athumb.jpg 10/100/1000 Mbps 32 bit PCI Gigabit Ethernet Card
ID#: ST1000BT32 $29.99
Gigabit ExpressCard (10/100/1000 Mbps) Network Card
ID#: EC1000BT $55.99
st1000btpex.athumb.jpg PCI Express 10/100/1000Mbps Gigabit Ethernet Card
ID#: ST1000BTPEX $69.99
cb1000bt.athumb.jpg Gigabit CardBus Network Card (10/100/1000 Mbits/sec.)
ID#: CB1000BT $64.99
RATE THIS SOLUTION
ok
Posted on Oct 17, 2008
How do I alter the screen magnification on a dell laptop
Hold down CTRL key and push += key to zoom in
Hold down CTRL key and push -_ key to zoom out
Apr 24, 2014 | Dell Latitude D410 Notebook
Where is the @ key on the dell latitude D410 keyboard
To get the @ key hold down the Shift key and then press the number 2 key
May 19, 2012 | Dell Latitude D410 Notebook
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
HOW TO REASSEMBLING MY LAPTOP FOR DELL D410?
Here's a link to the service manual for the Dell Latitude D410:
http://support.dell.com/support/edocs/systems/latd410/en/sm/index.htm
This service manual describes in step-by-step how to disassemble/re-assemble this laptop model.
Jun 12, 2010 | Dell Latitude D410 Notebook
I need to restore factory settings in my dell with out a disk
Dell Latitude D410 XP Restore Disk
134008.jpg Dell Latitude D410 XP Windows Restore Disk
This is an automated Latitude D410 XP restore disk. The Latitude D410 drivers are supplied in a special windows friendly format. This means that your Dell Latitude D410 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return your software broken Laptop back to the factory setup. There are also a lot of utilities and resources on this cd that you would of found on your Laptop when it was new in its original new condition.
Normally you would need to independently download and install each driver and often enough it will be the wrong one! If you already have other drivers installed it can get very over complicated with device drivers not loading showing errors (like code 10 device cannot start) To make matters worse you end up with allot of older and newer revisions of driver too.
With this driver recovery system all you need to do is wait until the Laptop can not find the device driver it is looking for and put this CD DVD in. Sometimes you may need to select the DVD CD as the location for your driver. That really is all there is to it.
Works every time!
Guaranteed!
THIS CD DOES NOT CONTAIN AN OPERATING SYSTEM!
YOU WILL NEED TO INSTALL WINDOWS FIRST OR USE IT IN AN EXISTING INSTALL.
This CD DVD contains every driver you need for your Dell Latitude D410 XP Laptop.
You are buying an automatic system that installs every driver onto your system with minimal user knowledge and interaction.
This recovery disk includes much of the original factory software and utilities.
THIS RECOVERY CD RESTORE DISKS IS DESIGNED SPECIFICALLY FOR THE Latitude D410 Laptop
Do not risk a bad installation by using cheap generic alternatives
Some of the drivers you would expect to find on the CD DVD are listed below but not all will be applicable to your Laptop and this list is for example information only.
-> Every driver you need for your Dell Latitude D410 XP System
-> Network drivers
-> Network card drivers
-> Drivers
-> Most factory setup software
-> Mouse drivers
-> CD rom driver
-> CD rom drivers
-> Express PCI
-> Display drivers
-> Graphics drivers
-> Graphics drivers
-> Chipset drivers
-> Chipset drivers
-> Detonator drivers
-> Download NVIDIA
-> Download sound drivers
-> Sound card drivers
-> Soundcard drivers
-> Scanner drivers
-> Sound drivers
-> Opengl drivers
-> Printer drivers
-> 3com drivers
-> Dell Latitude D410 XP system restore drivers
-> Audio Drivers
-> Aspi drivers
-> Device drivers
-> Audio drivers
-> Device drivers
-> Motherboard driver
-> Motherboard main board drivers
-> Video card drivers
-> Modem driver
-> Modem drivers
-> Modem dsl drivers
-> Video drivers
-> Ethernet drivers
-> Ethernet drivers
-> Wireless Network drivers
-> Intel Wireless card drivers
-> Video drivers
-> Radeon drivers
-> Base device drivers
-> S3 drivers
-> Windows drivers
-> Card Bus drivers
-> Windows Dell Latitude D410 XP Drivers
-> Windows device drivers
-> Broadcom drivers
-> NVIDIA drivers
-> OSBC drivers
-> PCMCIA drivers
-> TNT2 drivers
-> USB drivers
-> WAN LAN drivers
-> USB drivers
-> VIA drivers
-> VGA drivers
-> Web Cam drivers
-> ATI drivers
-> ATI drivers
-> VGA drivers
-> All your version of windows drivers
-> PCI bus drivers
Repairs ALL unknown device drivers
Dell Latitude D410 XP Restore Disk Restore Disk
FREE ADD ON 1
Depending on the age of your system, we have also included our own emergency driver re-detect software. This will remove and unplug all devices from your system and re-detected every driver automatically removing old and duplicates. This will in effect clean out the side of your registry that deals with hardware. No other restore disk has this software and can claim to clear your system hardware drivers.
FREE ADD ON 2
Some of our restore disks have an automatic system driver update included!
There are many applications that allow you to automatically update your drivers. These applications scan your system and the automatically download and update your drivers.
We are rolling this feature out in all our recovery cds over the next few months
TAKE OFF ANY IMPORTANT FILES (BEFORE YOU DO A WINDOWS INSTALL)
USE THIS RECOVERY CD TO RETURN YOUR Laptop TO THE ORIGINAL FACTORY SETUP!
Mar 28, 2010 | Dell Latitude D410 Notebook
Help! Win 98 Ethernet Driver for Dell Latitude C600 PC
just go to support.dell.com click on home and type in service tag or select the product model of your computer. on the drop down menu select the os - Win 98. if page has refreshed scroll down and click the arrow button beside network
Mar 01, 2010 | Dell Latitude C600 Notebook
Mic problem
I don't think the D400 series had microphones. I could be incorrect, but I don't think so ...
Jun 15, 2009 | Dell Latitude D410 Notebook
How to installed external DVD driver on my Dell LatitudeD410
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Apr 10, 2009 | Dell Latitude D410 Notebook
Ethernet card
Just go to this website and have the dowloading there:
www.nvdia.com and make sure you follow the installation very carefully.
I hope this will help you.
You are welcome
Please, rate this Solution.
Oct 16, 2008 | Computers & Internet
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
