Has anyone had any luck with the Belkin USB to SCSI adapter Model F5U115-UNV and the UMAX 1200S under windows ME? It is detected, but I get the following dialog message, "The test failed because the device is not available. Verify the connection and try again." when I run the test under the general tab in scanner & camera icon in the control panel. The scanner responds for a moment the parks and this dialog comes up.
Thank you in advance for any help that you may have.
I turned on the termination power thru a jumper inside the scanner and had no luck. I ordered and received the power supply to use with the belkin adapter and that has yielded no help. I previously was able to have my scanner at least recognized but thru messing with things while waiting on the power supply it will not even "see" my scanner now.
Thanx
Dan On Fri, 14 Sep 2001 07:55:50 +0100, "ph"
Was this solution helpful? Show your Appreciation by rating it:
