Hotpoint washer WT740which is 2.5years old has this am refused to wash. It will draw its first amount of water and then does nothing . Having cancelled the program (F) I tried to get it to fast spin but would not do that either. It did however pump out when I put it to that setting. The barrel will move freely by hand. Any suggestions please? Joan
  • bennff Oct 23, 2008
    Thanks for trying to help! Have found that it is in the control board, 2 places were burnt out, and after being soldered is now back in use! This washer was bought new in Jan 06 so not up to standard of the Hotpoints of years ago. I have found that the model no is actually WT740T. Thank you very much for your effort.
    Bennff
  • 750 Answers
Hello bennff,
Welcome,
2.5 years old from manufactures date or bought used???
Is this the correct model number found , ON THE WASHER?
WT740
It is not showing up in my repair search.
Where did you buy this washer?
Posted on Oct 16, 2008
  • Neil Golan
    Neil Golan Oct 16, 2008
    Try unplugging the washer for 10 minutes and see if this resets the system?
    This usually does the trick in the new programmable washers today!
    Let me know of your success.
    Thank you
    Huum
    Sorry, I am trying to find info on this washer!!
    Wash cycle will not start
    The appliance door is not shut properly.
    The ON/OFF button has not been pressed.
    The Start/Cancel button has not been pressed for at least 3 seconds.
    The cold water supply tap is not turned on.
    - Aquarius+ only: H20 is displayed.
    Aquarius+ only: Have you selected Time Delay (see Programmes and
    Option Modifiers).
    Machine will not drain or start
    There has been an unbalanced load and the machine could not spin
    (see ‘Automatic Features’, Programmes and Option Modifiers).
    Has the drain hose been installed correctly (see Installation)?
    Are the drain hose, standpipe or undersink connections blocked?
    Has the ‘Rinse Hold’ option been selected? ‘Rinse Hold’ indicator light will
    flash. To complete the paused programme press either the Start/Cancel
    button or the ‘Rinse Hold’ button (see Programmes and Option Modifiers).
    Aquarius only: (if available on your model) Has the Variable Spin Speed
    dial been set to ‘No Spin’ (see Programmes and Option Modifiers).
  • Neil Golan
    Neil Golan Oct 23, 2008
    Do you know why or what burned it??
    Huuum
Hotpoint hv8b 593g all lights flashing and sounds like its trying to pump water out all the time even when empty
Sounds like a sensor or a computer board is having trouble. My Samsumg Top Loader went after 2 years it refused to spin out anything always went off balance even when nothing was in it. These new washers are Junk! I went back to the old style now I get my work done with out stress! Also the old washer which is a Maytag only cost me $100. that beats a thousand dollar machine which I had and Samsung would only allow a certified tec look at it well that a problem in it's self just for them to look not work on it was very costly and I feel if you have to buy a 1 or 2 year extended warranty that tells me it is a piece of junk! I had a Maytag it lasted me 32 years till it burn up. That is a good product the ones they make today are junk throw aways it is very sad.The best I can tell you is get a used one the old style it can be fixed and they don't cost as much.
Oct 28, 2014 | Hotpoint Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer refuses to move to next cycle
Can you still open door when it has filled?If so it is intermittant door lock .If no new progame card required.
Nov 05, 2008 | Hotpoint Aquarius WD63 Front Load...
My washer
It sounds like you have a faulty inlet valve or module. Hope this helps.
Oct 02, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WF000 Washer
make sure you have both water valves working and check your water pressure is good too hope this helps
May 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fabric conditioner drawer full of water!
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
