Question about Home
Bathroom stall shower
I recently bought a home where the plumber installed the shower head way too high up on the wall. Is there any hand held shower faucet that I can get installed without ripping out and moving the existing shower arm?
  • Anonymous Mar 14, 2014
    plumber installed cord going bottom to top and it's tough to use
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Or add a 1/2 coulping and a peice of brass nipple and lower it where you want
Posted on Mar 03, 2013
    Problem Solver:
  • 8 Answers
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Posted on Oct 16, 2008
Am installing a Moen hand held shower ("Propel"). The instructions say I should install a backflow preventer. Where does that get installed? Inside the wall, or on the shower fixture itself?
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Dec 27, 2017 | Moen Home
Looking for company able to replace bathroom shower stall with glass door.
Just Google, as we have no idea where you live. I know people in Toronto, Canada if that is any good to you :>)
bathroom renovations (your town or city)
plumber (your town or city)
You will also find review is Yell.
replace bathroom shower stall with glass door toronto Google Search
Aug 30, 2017 | Home
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Feb 13, 2011 | Home
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Shower - Rain head won't turn off so hand held can be used solo.
Probably the fitting is not working properly. Please change the fitting.
Apr 17, 2010 | Plumbing
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Mar 26, 2009 | Home
Home Logo
524 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
