Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Noise sounds like sucking air when starts, if you turn water on the tap the sound stops. does this trew out the cycle
    Scholar:
  • 136 Answers
Have a look to make sure something has not fallen into the pump assembly, sometimes a hard piece ( like a pit ) or small utensil can fall into the pump and make a grinding style of a noise.
Q - My dishwasher is full of soap suds....help!!
Q - Can you use dishwasher pucks in every dishwasher?
Q - My dishwasher racks are getting rusty, is there anything I could do about them without having to buy new ones?
Q - My dishwasher looks dingy inside...is it time for a new dishwasher?
Q - My dishwasher wont drain, what can I check for?
Q - My dishwasher is making a noise, is there something I can check before calling for service?
Q - The dishwasher is empty when the cycle is over, but the next morning there is water inside the dishwasher, what could be wrong ??
Q - I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
just click on the above questions and the answer will be displayed on your screen
Which detergent type is better, liquid gel or powder?
We recommend the powdered/granular detergents--like Cascade--because sometimes the gels don't perform as well. We've also found that prominent brands are better than some of the generics.
Do I need to clean the inside of my dishwasher? It depends. If you use the dishwasher at least twice a week, you don't need to clean the inside. Otherwise, if it begins to get moldy inside--or if the residual water at the bottom of the dishwasher smells bad--put detergent in the soap dish and run the dishwasher empty, through a complete cycle.
Is there any routine maintenance for my dishwasher? Yes. See our Maintenance Tips section.
My dishes aren't getting clean. What should I do? Check our Troubleshooting Guide for help with functional problems.
Do I have to rinse my dishes before washing them? Not usually. Most dishwashers handle the normal food residue left on dishes after eating, if you first scrape the dishes to remove any larger bits of food. But if anything is burned, melted, or stuck to the dishes, rinse and scrape them well, before you put them into the dishwasher. Leaving some residue is actually best, because the protein in the food reacts with the soap for more-effective cleaning.
My dishwasher takes too long. What's wrong? It may be a model that pre-heats the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Should there be water in the bottom of my dishwasher? Yes. All dishwashers leave a small amount of water in the bottom, to keep the seals and pump wet. If the seals dry out, they can become brittle and begin to leak water.
My cups and glasses are coming out spotty and filmy. What's wrong? For spotting only, try using the heated drying cycle. If that doesn't help, try one of the rinse-aid products you can find at your supermarket.
Film can be caused by a couple of things:
  • It could be from a lack of water flow within the dishwasher--see the Troubleshooting Guide section for more information.
  • It also could be from hard water. If you can remove the film with vinegar, it's probably caused by hard water deposits.
Etching--a corrosion of the glass--can be caused by using too much detergent. A rainbow hue on the glasses is the first sign of etching. Try cutting in half the amount of detergent you use.
Do I really have to run the water in the sink before starting a cycle? Yes. Dishwashers work best with very hot water. Letting the water at the sink run for a few moments (until it's hot) before turning on the dishwasher brings hot water to the dishwasher faster.
Posted on Oct 16, 2008
Grinds beans OK and goes through the cycle but no coffee comes out even on expresso and not sounding right. Anyone know why?
If the machine is making a loud rattling noise it may be that the pump is sucking air and not water at start up. Clean out the machine, reassemble, install water tank and tilt the machine over backwards at approx 45Deg, and start the rinse cycle again. This normally clears the air lock. Good Luck.
Sep 16, 2015 | DeLonghi EAM3500 Espresso Machine/Coffee...
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
Aug 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
There is a whooshing sound when I turn left in my 2005 Corolla. Almost like liquid is shifting from one side to another. It almost sounds like a it's sucking air. Barely makes this noise on gentler turns....
The heater box may be retaining water condensed by the evaporator. Find the drain hose on the engine compartment side and clean it out with a long screwdriver.
Sep 17, 2017 | 2002 Oldsmobile Silhouette
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kitchenaid dishwasher sucking noise when ON
the sucking noise is the water valve, opening but it doesn't not sound it getting any water in. have the water valve replaced.
do you get any error messages on the display?
Sep 13, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Strange noise from my Bosch Dishwasher SHU66C02UC/14
It just the pump noise. Since your dishwasher works properly you can ignore this noise.
Sep 09, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
285 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
