Question about Canon imagePROGRAF W7200 InkJet Printer
Error : print head error . turn power off - Canon imagePROGRAF W7200 InkJet Printer
  • 905 Answers
Have you tried reseating the print cartrige or the wire strip that connects to it?
Posted on Oct 16, 2008
Hardware error 03800500-2F43
Most of the time its the print head, this is very costly. The print head tends to clog if you don't print often. Try to print at least a test print once or twice a week.
Jan 31, 2013 | Canon imagePROGRAF iPF6300 Large Format...
I have a Canon printer PXMA IP6000 D. I suddenly will not print. I get a code, "Service Error 5200". I have tried turning it off and checking for a paper jam. Nothing works. Can you help me? Gary
1.Reset the printer
Follow these steps to reset the printer:Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2.This is the waste ink reset proceedure and should clear the error (Waste ink absorber full [5B00] )
1. Power off printer2. Hold Resume button then press and hold POWER, the beeper will sound once.3. Keep holding POWER and release RESUME 4. Press RESUME twice, then release all buttons 5. When the indicator lights steady, press RESUME four times. The indicator should be orange. 6. Press Power to set data .
3. According to the service manual error 5200(LED alternateblinking in orange and green) indicates Print head temperature rise error ( The error means the print head is getting too hot.)
- Re-seat the print head
Confirm that the printer is powered on.Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
After confirming that the print head holder has moved to the center, open the inner cover.
Remove all ink tanks. >> click HERE <<
Raise the print head lock lever and remove the print head. >>Click HERE <<
Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard >> Click HERE <<
Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner. >>click HERE<<
Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position. >>click HERE<<
4.If the problem persists ,the print head may be defective and needs replacement .Here's a link to your service manual in case you need to confirm >>manual/hp/iP6000Dsm.pdf <<
Oct 15, 2011 | Canon Office Equipment & Supplies
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
My Canon MP270 printer shows the following error 5200 P08
P08 (Print head temperature rise error) : 6. P08 (Print head temperature rise error): thermalprint head temperature exceeds a threshold.
Replace the new cartridge print head and / or change a new logic board.
Jan 12, 2011 | Office Equipment & Supplies
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
I am getting a "wrong print head" error message.
Turn the printer off.
Disconnect the power-cord from the wall-outlet.
Reconnect the power.
Turn the printer on.
If you still get the same message, it's time to responsibly recycle the printer,
and buy a replacement -- maybe you can buy a new PIXMA that takes the same ink-cartridges???
Dec 08, 2010 | Canon PIXMA MP810 All-In-One InkJet...
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
EPSON DFX-9000 ERROR CODE = OD and OB
error code OB turn off the printer, why?
Sep 17, 2008 | Epson DFX-9000 Matrix Printer
Canon imagePROGRAF W7200 InkJet Printer Logo
449 people viewed this question
old marine
old marine
