Question about Dell E153FP 15" LCD Monitor
Monitor not working properly after a windowxp re-instalation
Dell Optiplex GX260 does not correctly acknowledge monitor (E153FP) after a format and re-instalation. Absolute minimum of screen resolution displayed. All attempts to adjust rejected. Identical problems with ethernet and sound card. Refuses to accept any driver updates.
  • Anonymous Apr 06, 2009
    unable to set resolution on monitor after installing Xp Professional on new HD can't locate site for drivers
  • jason May 11, 2010
    what kind of video card ? or is it on board ?
I have long since gone to Dell support, the machine neither recognises the harware nor any attempts to upload the Dell drivers. It says 'unable to open file'. Regarding the monitor and soundcard It is like the machine has become largely blind and dumb.
Posted on Oct 20, 2008
  • 37 Answers
It sounds as though you need to install drivers for the hardware that is not working properly after your re-formatting and re-installation of windows.I have found that although windows xp will provide almost any drivers needed, many drivers for Dell systems are not. Just to check which hardware is not working properly, go to the start button, go to control panel, then performance and maintainance, then system, next hardware, and finally device manager. Any hardware listed that has a yellow question mark to the left is not working properly, most likely because the drivers are not installed. The easiest solution is if you have the original CD's that came with your computer. If you do, and you have one that is labeled " resource CD ", or if it is labeled that it contains the device drivers for the hardware not working your task should be relatively easy. Just insert the disc, it should auto start, if it does not, start it manually from my computer. It will automatically provide the drivers needed. If you do not have the CD needed, you can write down the specifics of the hardware not working from the device manager by clicking on each item and going to properties. After you have that information, go to the following Dell website and manually look for and download the drivers you need. Good Luck. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
Posted on Oct 16, 2008
I installed a new AGP video card on my Optiplex GX260, when the computer is plugged in, I can hear the fan going but it does not boot up, help?
Unplug the computer, Check if the cable connections to everything, reseat, you may have inadvertently disloged a connection when you installed the card. wait 30 seconds or so, plug in, reboot. You say the monitor is fine, what do you see on the monitor?
Jan 18, 2013 | Dell OptiPlex GX260 PC Desktop
How can i get the doenloads of dell optiplex
put op system disk in the disk drive... start the computer then it should say that the hardrive is not formated..then it should offer to format it....or/ check the bios... it may let you format...
Jul 20, 2010 | Dell OptiPlex GX260 PC Desktop
I have no video with my optiplex gx260? Help!!!
if you are using on bored video, then its very possible that their is something wrong with your monitor, if your using a video card, and its the same video card you used on your old mother bored, then its probably the video card.
Mar 18, 2010 | Dell OptiPlex GX260 PC Desktop
My husband has a dell gx260 optiplex and it wont reconize the monitor since he reformatted can u help me
Hello
possible corrupt install of operating system.windows may not have installed correctly.
Can you reboot with install disc in cd rom and see if you get a menu for windows installation?
Feb 01, 2010 | Dell Computers & Internet
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
Display problem
The problem might be with your monitor, please check it properly if it is okay and also try to check your system on another Monitor.
If your monitor is okay, then there are two possible causes:
1) There might be a problem with your slot on motherboard try to connect card with another one if your board have.
2) There must be a problem with your graphics card. If it has a warranty, do replace it ASAP.
If you have anything else to clear, please do share with me.
Kind Regards,
Khawar Khalid
Jul 08, 2009 | Dell OptiPlex GX260 PC Desktop
Using dual monitors on a Dell Optiplex GX260
You cant.. Unless the nvidia card you added has two video OUTs. Plugging in a aftermarket card causes the motherboard to disable the onboard video..
If your nvidia card has two "outs" then you can use two monitors... most newer nvidia cards support this. sometimes it requires an adaptor, but usually it was included in the box
Apr 22, 2009 | Dell OptiPlex™ GX260 PC Desktop
Sound drivers for Dell optiplex gx260
Solution #7 fixed my problem.
GX260 Dell audio driver problem turn on audio in the bios.
Jul 12, 2008 | Dell OptiPlex GX260 PC Desktop
Dell E153FP 15" LCD Monitor Logo
154 people viewed this question
Alun Cox
