Question about Samsung SyncMaster 750S Monitor
Vga pinout schema for samsung 753dfx
Hi,can you give me an exact description for the vga pin schema...
I have it like this down,but I need to know which colour the other cables are exepte 1-2-3-6-7-8
thanks
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
    Brigadier General:
  • 6,966 Answers
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 16, 2008
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
Aug 29, 2009 | Computers & Internet
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Info on the SW9800 Subwoofer
I would like to buy your subwoofer for my broken system. Please contact me ASAP
adam.roseneck@gmail.com
Dec 23, 2008 | Philips Cineos HTS9800W System
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Projector Cable
Found a pin-out at: http://www.diyaudio.com/forums/diy-projectors/78108-ezpro-550-rgb-cable-pinout.html
1 2
2 5
3 9
4 No conectar
5 14
6 1
7 6
8 13
9 15
10 11
11 no conectar
12 No conectar
13 3
14 12
15 No conectar
You probably need to have a special cable made up.
Jun 24, 2008 | CTX Optoma EzPro 600 Multimedia Projector
Samsung SyncMaster 750S Monitor Logo
1,555 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
