Question about Lexmark Office Equipment & Supplies
We cannot receive faxes. The machines tries to connect but fails due to a transmission problem
  • Mum No 2 Oct 16, 2008
    It is a BT DSL line but the fax is plugged into a filter
  • jason May 11, 2010
    do you have dsl line or regular phone line?
  • 905 Answers
You should disconnect the phone line and the power to the fax , they will lock up sometimes and need what is called a cold reset , otherwise there may be a problem with the filter or the fax itself
Posted on Oct 17, 2008
What's error 345 with HPOfficejet j5780 all in one while faxing?
error 345 while faxing is related to Communication error. This error is not related to printer hardware issue.
Below are the possibilities ....
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  2. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  3. The remote user pressed the Stop key while the reception was in progress.
    The suggested solution would be as follows....
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Jun 02, 2014 | HP Officejet Pro L7680 All-In-One Printer
Error 322 How to fix it?
There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 15, 2013 | HP Officejet 7210 All-In-One InkJet...
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
I HAVE TRIED TO FAX BUT I KEEP GETTING ERROR 344 THE FIRST PAGE GO THROUGH AND THEN IT TELLS ME FAX FAILED I'VE TRIED 5 TIMES THE RECIPIENT SAY THE FAX IS READY TO RECIEVE
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted or:
The remote user has pressed the Stop key while the reception was in progress or:
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the fax session was using error correction, disable ECM if not already.
Mar 24, 2011 | HP Office Equipment & Supplies
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
Try
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Error code 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error 350
Error 350 means...
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Try this solution...
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved. (To turn off the ECM, simply press the setup button on the pritner, use the right arrow and select advance fax setup on the options. Press ok under advance fax setup. Use the right arrow and select Error Correction Mode. Press ok and select Off.)
*Try sending at a lower transmission speed. (To lower the transmission speed. Press the setup button, go to advance fax setup. under advance fax setup, look for Fax speed. change the fax speed to slow)
After you have done the T/S, try sending a fax again.
Hope this would resolved your issue.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
I have trouble faxing over my voip line
SOUNDS AS IF YOUR PHONE LINE IS THE PROBLEM. LAWRENCE
Sep 25, 2007 | Brother FAX-8360P Plain Paper Laser
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
