Question about Samsung SGH-E370 Cellular Phone
Mobile phone will not start. Thought battery had run down, so recharged it, it didn't start up again. tried removing sim & allowed to rest for 30 seconds , still no luck. Phone hasn't been dropped, was in pocket all day.
    Sergeant:
  • 226 Answers
The battery could be undercharged, try with another battery, other wise, could be a software issue
Posted on Dec 29, 2009
After aoolwing my Samsung to run down completely I tried to recharge. it now tells me that it is recharged to 100% BUT IT WILL NOT TRN ON
The battery has failed in all likelihood. The charge indicator on phones is not accurate as it only measures voltage and not amperage. Most Samsung devices use batteries that are not intended to be run completely dead. New batteries should be allowed to discard to less than 10% and fully recharged the first 4times of use. After that it ddoesn't matter when it's recharged.
Oct 17, 2016 | Samsung SGH-E251 Mobile Phone - Black
Mobile phone will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 02, 2012 | Doro Phoneeasy 410Gsm Easy Gsm Sim Free...
I recharged my 6300 battery and now, when I switch the phone on, the screen flashes twice and the phone switches off. A couple of weeks ago the keypad wouldn't work but it came right so I didn't...
some of the nokia 6300 mobile as the same problem after changing there battery your battery does not fit to your model mobile phones change the battery or make your battery to fit to your mobile then it will be back as good it was.If you have same problem means take out your memory format your memory card.
Jun 10, 2011 | Nokia 6300 Cellular Phone
How d i reboot my samsung behold 1
to reset this phone or what you called reboot witch is really not the case is:
1. Take the phone battery out
2. Allow phone to sit for what 20 -30 seconds
3/ put battery back in
If that does not work for you looks like you purchased form T-mobile or bought it form some T-mobile customer after witch you will need to take it up with the manufacture.
Hope this helps please do not forget to leave positive feedback/ratings for your free answer today.
Oct 22, 2010 | Computers & Internet
T-Mobile sidekick II keeps resetting
I had this problem with a new phone, and T-mobile gave me the following instructions.
Try this first:
1) Turn on phone with SIM chip in it.
2)hold down the "@" + "1" + "0" down simultaneously until phone turns off, then back on again. This should fix the problem. otherwise try this,
1) remove battery and SIM.
2) press and hold down the "w" key, and while holding it down insert the battery only.
3)A little face will appear on the screen, then a reboot button. Press the reboot button. Once the phone reboots, insert the SIM. One of those two should fix the problem.
Oct 04, 2009 | T-Mobile Sidekick II
After 3 times restarting the mobile shut down
Hi Friend,
Please find the below mentioned steps and kindly follow the steps,
1.Switch off the mobile.
2.Remove the sim card,battery and memory card.
3.Hold the switch on button for 20 to 30 secs,
4.After that replace the sim card and the battery.
5.Now switch on the mobile,
6.After it has switched on now replace the memory card.
Regards,
Ayyasam
Aug 26, 2009 | Nokia 5310 Cellular Phone
My sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Htc 8925 error "sim card not detected" have removed and replaced sim card have removed battery and rebooted have swithed sim card to annother phone, works fine have replaced sim card with a working sim...
I see this is an older post but I wanted to post the solution that helped me after a very frustrating 30 minutes. I was having the same problem. I bought a new phone (HTC 8925), and when it arrived, I plugged it into the wall charger and inserted the SIM card. I still got the "SIM card not detected" error. After removing an inserting, checking all possibilities of having done it wrong, and searching the internet only to not find the answer, I tried something that worked.
My solution: When I unplugged the charger and reinserted the SIM card, it worked immidiately. It was as if being plugged into the charger was not allowing the phone to reboot completely, even though I was powering the phone down and back up again. Since this was the solution, if you are having the problem and not connected to a charger, I would try a soft reset by pressing the stylus into the button (tiny whole) to the right of the USB port.
Mar 23, 2009 | Cell Phones
Screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
T-mobile Dash Won't start
This will fix it:
Turn the phone off, remove the battery for a minute. Replace the battery.
Hold down the right and left soft menu keys simultaneously then press the power button for a couple seconds and release. Keep holding down the soft keys until the hard reset screen displays.
The reset screen will tell you to press 'Send' to reset or any other key to cancel. Press and hold 'Send', which is the button with the green phone on it. After a couple seconds, the device will start to do its thing.
This will take some time so be patient. It will have a question or two as it goes through the process. Answer.
Don't worry, you won't lose your branding (e.g. if you are a tmo customer, you don't lose the ability to have myfavs and your phone keeps the tmo branding/settings).
Apr 30, 2008 | T-Mobile Dash Smartphone
Samsung SGH-E370 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
