Question about Intel D865GBF Motherboard
Bios flash can i flash dead 845 gvsr mother board bios rom in a different mother board with uniflash flashing tool .can i use bios updating file for this purpose
Error 4
Posted on Feb 27, 2009
  • 55 Answers
firstly i want to tell you that every motherbord bios has a unique program to control the devices.
it this bios is fit on another board casing then you try to firstly run the mother board with old bios. then copy the bios code by any flashing tool and then remove this bios and fit the dead mother board bios in the casing then flash it and then update it which file you copy the old one.
then your motherboard perhaps go on with the dead motherboard bios.
thanks
ramesh
Posted on Nov 19, 2008
Tip
Reflash Via EPIA-M 1000g BIOS when board is dead
I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.
OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.
Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.
You should at least have some experience in DIY in computers .
1. Find a mobo of an old  pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.
No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.
2. Try to see if it boots, if all ok..
3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.
4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.
5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.
6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools
7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...
8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.
If you'd like to thank me or ask details..mail me at www_offspring@yahoo.com
on Jan 19, 2012 | VIA Epia M10000 Motherboard
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
CMOS BATTERY LOW CMOS SETTINGS WRONG CMOS MEMORY SIZE WRONG. I was getting that error, and then i went and brought a brand new battery, the CR 2032, the same that came after...After i booted it up, went...
  1. here are the instructions to Flash Your BIOS -
don't forget to read the information that's included and related to flashing in your motherboard's manual. Yes, dig that manual out (or if you can't find it then download it from the manufacturer's website; it's usually available) and read it!
Four of the most common flashers are: AWDFLASH, AMIFLASH, UNIFLASH and AFUDOS (only for ASUS boards). Out of these the UNIFLASH (get it here) is the universal flasher that can usually flash every BIOS; it has awesome compatibility capabilities. Keep in mind that BIOS flashing can be (and is) dangerous, because in the case of a bad flash the data ends up corrupted and your computer won't POST anymore. So I'm recommending wholeheartedly that you use the BIOS flasher that's explained in the manual and provided by the manufacturer of your board. Read the manual, do your research and when you're ready, then and only then proceed to follow the instructions.
After you get your flasher you need the latest BIOS flash file. First find out your motherboard manufacturer's name and your board's exact name and specifications. Visit your manufacturer's website and download the latest non-beta version (betas can be risky and I don't suggest you experiment if you can't fix it if a bad flash happens; we'll discuss that a bit later). These files usually have ".ROM" or ".BIN" extensions. Later on I'm going to call the "latest BIOS file" "newbios.bin."
I'm going to give you examples of how to use UNIFLASH, AWDFLASH, AMIFLASH and AFUDOS. Read them strictly as examples and do not proceed to flash your latest BIOS version before you understand what each option gives and how to use these flashers.
Flashing with UNIFLASH:
A:uniflash.exe newbios.bin
Flashing with AWDFLASH:
A:awdflash.exe newbios.bin /py /sn /cc
Flashing with AMIFLASH:
A:amiflash.exe newbios.bin /A+ /-B /-C /-D /E /-G /I /L /N /R /V
Flashing with AFUDOS:
A:afudos.exe /inewbios.bin
Even though the above commands do work it's always crucial that you read what every command does and understand them. First of all, once you're booted into MS-DOS, execute the flashers without commands and options. Just use a simple "awdflash.exe" or "amiflash.exe"-- then a help screen (which explains all of the available commands and options) will appear. Read that thoroughly before proceeding and follow the instructions.
As a side note, UNIFLASH has a UI (user interface) so it definitely helps beginners. Execute the "uniflash.exe" and the UI will appear and guide you through.
please dont forget to read precautions here
http://www.devhardware.com/c/a/Hardware-Guides/Why-and-How-to-Flash-Your-BIOS/2/
Mar 07, 2010 | Computers & Internet
About Bios Upgrade
1st update your ROM BIOS
here a site may help you
http://www.uniflash.org/
http://wims.rainbow-software.org/
or
in this link it has intruction how to flash it and all you need its there
http://support.octek.com.au/Products/MainBoards/BIOS/bios_0014.htm
Hope it work for you ^_^
Jun 09, 2009 | Intel Motherboard
BIOS Files
Hi!
Have you visited www.cnet.com I always start with this site for all my driver/software downloads, never failed yet!
Good Luck, please press the Blue button if sorted and happy with My FREE effort, Thank You!
Paul 'W' U.K.
Feb 02, 2009 | IBM NetVista PC Desktop
SATA is not enabled in bios.
the flash files were probably corrupted when downloading them, download the correct bios update from the computer support website and try to flash the bios again
hope this helps
regards
Nov 20, 2008 | AOpen XC Cube EX661L (95EZ619321) Barebone
Bios problem
pl guide to where it will be availble bios copier circuit for all baords
Aug 02, 2008 | Intel D845GVSR Motherboard
Error E9 on 845 gvsr
i have a 845gvsr mother board power not coming led is binking but not powered coming. what is the soution......
Jun 26, 2008 | Intel D845GVSR Motherboard
Intel D865GBF Motherboard Logo
423 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
