Question about NEC Computers & Internet
I have a NEC laptop, and when it reboots the mouse/touch pad does not work
  • 103 Answers
Hi
If your mouse has a switch try turning it off and then back on. Else connect an external mouse via the USB port or any other port and reinstall the driver for the mouse using the driver recovery installation CD you were provided with, Go to control panel to do so. That should do the job.
Genius Guy
Posted on Oct 16, 2008
Why does my touchpad on a acer aspire e11 keep freezing?
The touch pad might be faulty. Try to reboot the laptop after cleaning touch pad with a clean damp cloth. If nothing happens then the sensors under the touch pad could be faulty.
Sep 20, 2014 | Computers & Internet
Can u guys help me?? i got a problem to take out the HDD.. my laptop model is NEC VERSA S3301.. i don't know how to open it!!
HDD is on the front side with the mouse sensor.if touch pad is most left then hdd is on right side and if touch pad is right most then hdd will be on left side.
you can find hdd by open the keyboard side.there will be two or four screw on th backside or bottom of laptop.open these screws then pull touch pad carefully.dont force it may be you open wrong screws rather then correct screws.
hdd always on the side of touch pad its now on you how to open it.
Jun 28, 2011 | NEC Versa SXi Notebook
My pointer is frozen on my emachines laptop? I've tried restarting it but that didn't help.
I hope your touch pad or touch pad driver is not working - try to reload the driver and see if the problem persist its your touch pad - then connect a usb mouse externally and see its working
Jan 20, 2010 | Acer Computers & Internet
My laptops mouse is not working
IF you are referring to the external mouse attched to your laptop
then please check the same mouse with some other systm to verify if
the issue is with the mouse or with the laptop.
if the mouse is working fine with other system, then you need to
contact the service provider of your laptop.
Otherwise you have to buy a new mouse.
If you are referring to the touch pad of your laptop not functioning
properly, then please check the touch pad settings through control panel.
otherwise please shut down the laptop.
Take out the baterry out & wait for atleast 1-2 minutes.
Reinsert the Battery in the laptop & reboot the laptop.
Check if the mouse is working fine or not.
If the problem with the laptop still persist, please contact your
laptop service provider for further support.
Hope this will help you in resolving the issue.
Cheers!!!
Vivek
Dec 26, 2009 | Computers & Internet
I have a Satellite L500, need help turning mouse off so I can use touch pad, I got the laptop used and they used a mouse and I would rather use touch pad and don't know how too turn mouse off.. when i...
If it is not a normal mouse then From the Control Panel->Add Remove programs remove the mouse drivers. and reboot the laptop. Else go to Control Panel->System->Hardware->Device manager. Remove the mouse that is installed there. DO NOT REMOVE THE TOUCH PAD. And compute happily ever after.
Nov 16, 2009 | Computers & Internet
My aspire 5310 mouse pad is not working
either your mouse pad is broken or someone or some program has shut off the driver for your touch pad. I would reinstall the drivers and reboot. if that doesnt fix the issue, I would then look into replacing the pad.
Sep 12, 2009 | Acer Aspire 5050-3242 Notebook
The mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Aug 20, 2009 | Toshiba Satellite A135-S4527 Notebook
Frozen touch mouse
Get your laptop utility CD/driver. Borrow a USB mouse and then you access the laptop driver so you can reinstall the touch pad. That should work (it worked for me).
Then before ejecting your utility disc/driver, you copy the touch pad folder and then paste it to your desktop so the next time you'll need to reinstall your touch pad, you can readily access it.
May 27, 2009 | Dell U0636 Mouse
Mouse pad not working
A mouse pad is a thing you put your mouse on....
now what you are talking about is your touchpad.
Check these first:
  • some laptops have a switch that turns off the touch pad (usually a button right on the topside of the touchpad)
  • did you reboot completely? full shutdown, then power on?
  • goto the device manager (with a usb mouse of course) and find the touchpad... delete the device... then reboot again it should try and find the touchpad and ask for the driver, point it to the directory that you have the driver located.
good luck!
Apr 21, 2009 | Computers & Internet
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Computers & Internet Logo
85 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
