Hot water is shooting out of the gas water heater
  • 121 Answers
It sounds like your tank is ruptured which unfortunately will have to be replaced
Posted on Oct 16, 2008
Is there trouble shooting instruction for a R75LS Rianni
I would contact the manufacturer to see if they can enlighten you as to what it might be .
Oct 09, 2016 | Rinnai R75LSe Natural Gas Tankless Water...
Not fireing up
Mark, It sounds like the gas valve may be bad. You may want a tech to diagnose and repair.There are other things to check also air intake and exhaust must not be plugged and the exhaust fan must be operational if equipped.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix water heater will not stay lit sealed combustion no hot water
Gas Hot Water Heater Repairs
Water Heater Gas Valve Replacement
Hot Water Heaters How to Change Gas Valve on Hot Water Heater
Apr 24, 2016 | Water Water Heaters
Trouble shoot heater hot water valve
It's not the GV. It's the Thermostat calling for heat when set to A/C and/or the Controller on the furnace.
The GV with a Hot Surface Igniter has nothing to do with the problem described as it only controls burner ignition when heat is called for.
Stay away from working on Gas Valves if you are not a licensed Technician or Tradesperson. Explosions can kill people and destroy property
Sep 08, 2014 | Honeywell SV9520H8513 Direct Hot...
Can't light pilot light on hot water service. Gas to property is connected as the gas stove works.
There should be a trouble shoot guide on the hot water tank. I have had to do this many times. You just need to read the trouble shooting guide & be very careful. I hope this works for you.
D :)
Feb 01, 2013 | Water Heaters
Very minimal hot water being produced from my water heater
1) Clean air intake, and do required yearly maintenance.
2) Gas control valve thermostat could be going bad, causing disruption of gas to pilot, and uneven heating of water.
3) Without knowing brand and model number that shows on label on side of tank, it is difficult to add specifics.
Dec 31, 2012 | Water Heaters
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
I have a honeywell pilotless hot water heater control model wv4460e. This unit is not working and I was trying to trouble shoot it. I have tried to unplug it and plug it back in and it seems like the...
The blinking light is actually an error code. See the trouble shoot section in the manual:
Jan 28, 2011 | Kitchen Ranges
No water comes out of the hot side of my shower or bathtub
Based on gas prices, often gas hot water heaters can be a more cost-effective option than electric models and preferred by many homeowners. However, gas hot water heater models can have their own set of problems that differ from electric versions. You will not find it difficult to perform some basic troubleshooting to resolve an issue with a gas hot water heater.
  1. 1 Determine if the gas supply has been shut off. No gas will cause the hot water heater to stop producing hot water. Turning the gas supply back on should be your first troubleshooting technique.
  2. 2 Check the pilot light. If you are experiencing no hot water, the pilot light of your gas hot water heater may have distinguished. Turn off the gas source and place a match over the pilot light tube to relight it.
  3. 3 Adjust the thermostat of your hot water heater. If you find that the hot water runs out quickly or does not get hot enough, you may need to set the temperature of the gas hot water heater higher. Typically, set the dial between the medium and hot setting for adequate hot water.
  4. 4 Inspect the gas hot water heater. The burner orifice and flue can both become clogged on a hot water heater. Turn off the gas and use a wire brush to clean out any debris that may have become lodged in these sections.
  5. 5 Ensure that all the burner access covers are in place. If the pilot light will not stay lit, it could be due to exposure to drafts.
  6. 6 Flush the tank. Certain deposits can build up over time when using a gas hot water heater which can cause the tank to produce a banging noise. To flush it, turn the heater off and open the pressure relief valve and drain valve on the water heater. Use a hose to flush water through the system until the hose runs clear.
Oct 15, 2010 | Kohler Home
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
