Question about Panasonic Audio Players & Recorders
5CD changer SA-Ak640 will not open disc trays just diplays "CHGR ERR" is locked on disc 5
  • Suegra Oct 16, 2008
    thank you thats What I will do
    Suegra
  • 4,234 Answers
The loading mechanism has jammed somehow. When powered on, the unit attempts to get to a known position. If that fails, the message you indicate is displayed. The only way to resolve this is to dis-assemble the unit and rebuild the mechainsm. This should NOT be attempted without the service manual. There is a particular way to re-assemble these so that the gearing is correct. There are small gears and levers that need to be aligned properly. Also, there may be a broken lever or gear that needs to be replaced. I have rbuilt a number of these and the parts (if needed) are cheap (<$4 total).
I wold suggest that you bring this to an authorized Panasonic service center.
Dan
Posted on Oct 16, 2008
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for...
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Jul 05, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-AK640 mini stereo system and I'm receiving an error message ''CHGR ERR''. The disc tray will not eject. I've tried to power the stereo off and on several different times. What else...
The CD loading mechanism is out of time and has not reset correctly. This cannot be reset. The loading mechanism must be dis-asembled and rebuilt. This is not a DYI repair. Any Panasonic service center can repair this for you.
Dan
Jul 06, 2010 | Panasonic Audio Players & Recorders
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
I have a err code "chgr err" on my panasonic sc-pt960.
This would indicate a CD/DVD Changer Error.
The system thinks there is a stuck disc or other wierd problem with the CD/DVD changer.
Unfortunately these issues are rather hard to fix, due to the way the changers work.
Opening these units isn't that hard, however fixing an issue with the changer is very difficult and is best left for a specialist.
You may need to contact a local Panasonic repairer to get this one fixed.
Use the link below (if you are in the US) and enter your model number and ZIP code to locate your nearest repairer.
http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Header%20Support-_-Support%20For%20Customers%20Link
Best of luck, and sorry that I could not be of much more help than this.
Jun 22, 2009 | Panasonic SC-PT960 Theater System with...
Blaupunkt 5CD indash changer CODE
email me codes@blueice-electronics.co.uk
will email back your code
or you can buy it from www.carradiocode.co.uk for £3.50
Regards
Mark
Oct 29, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
243 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
