The problem is with the door rubber of my beeb washing machine model wm1510w. my dog managed to pull the door rubber and the wire that holds the rubber in place off the machine and i havent been able to get the wire back on to the machine any suggestion on an easy way to refit the wire?
How to insert the new part of the door it s rubber of the LG WASCHING MASCHINE TYPE MODEL WD-8016( 0-9) T( U ) P
please PHOTO FROM INSIDE TKS IN ADVANCE
Posted on Oct 16, 2008
How to remove remove rubber seal between door and drum
Hi,the door seal is held in place with a wire with spring on it,just open door get hold of rubber witch is attatched where door closes,
if you pull on the rubber at the edge you will see the wire you will have to get a flathead screwdriver to prise it out,once you take the metal band off just pull the rubber off,then if you pull on the rubber the inside bit of the rubber will come out.
hope this was some help.
Apr 05, 2015 | Zanussi Washing Machines
WM1510W washing machine power light comes on but the machine does not work?
The electronic controller board is faulty or, a door switch is telling the machine that the door is not secure. Jump around the door switch with a "jumper wire" and see if this fixes the problem. If not, then you have to replace the controller.
Aug 18, 2014 | Washing Machines
Machine is not using conditioner
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 13, 2013 | Beko Wm1510w, Wm6142w, Wm6152w Washing...
How to remove door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko Complete Door Wm1510w 2816000500 Wma10w Wm1510w washing machine How to Replace Beko washing Machine Door Seal
Apr 24, 2012 | Beko Complete Door Wm1510w 2816000500...
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
HOW TO ASSEMBLE MY WASHING DOOR CATCH,SPRING AND CATCH MODEL NOHNF 7138-80
Just open the front door of the unit and remove the rubber sleeve from the front cover you will find the iron ring just remove it first then you can easily remove the rubber sleeve and then you will see the two screws which holds the door lock switch just remove it and hold the door lock switch with the hand and see the wire connection properly when you are refixing it the door lock will work properly
Jan 05, 2010 | Washing Machines
Beko wm1510w bearing?
Hi there.....this rattle can usually be associated with failed or failing bearings.......simple test to follow....with machine switched off and door open...put your hand in and try lifting the inner wash drum...there should be NO MOVEMENT...movement indicates failing or failed drum bearings
regards Sir Galahad
Nov 09, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Hello my problem is that my dog pulled the rubber off the front of my washing machine and when i try to put it back on im not able to get the wire that holds the rubber in place back on, the machine is a...
This is tough sometimes. Just start it one one side (opposite the spring), and try to "walk" it around with a pair of screwdrivers. It gets frustrating at times but it will go.
Oct 16, 2008 | Washing Machines
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
