Question about Refrigerators
Westinghouse Ref Just bought a slightly marked 2 door ref. Who long do I let it sit before I plug in to get it going. Some people told my 6 hrs to let the freon settle
    President:
  • 1,462 Answers
Leaving for 6 hours should be ok. reason is nothing to do with freon (not used nowadays anyway) but because there is oil in the compressor and if has been tilted a lot, the oil can get up the high pressure pipework and cause a blockage
Posted on Oct 16, 2008
How much to buy a new oven door for Westinghouse POH967S/1
This MIGHT be the part.$80.85 +S+H.....https://www.repairclinic.com/PartDetail/Westinghouse-Range-Stove-Oven-Outer-Door-Glass/316406403/1062329?ss=a13b89i530&TLSID=1779&Ref=611198&gclid=Cj0KEQjwrsDIBRDX3JCunOrr_YYBEiQAifH1FmowBLo5d2_ciqlHmfN2bm8mLlnE1Bj9_vmm8W7q-0caAq7l8P8HAQ
May 09, 2017 | Ovens
Why are the sides of my new Samsung RT22FAJBDSA (8.3 cu. ft.) Ref was so hot although the inside was cool?
Did u follow the unpacking and installation instructions??
Are the sides,bottom,and back of refrigerator clear of all obsticals?
Did u remove the plastic from the ac cord prongs?
Sep 22, 2014 | Refrigerators
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
No heat
Could be that the breaker open on the heating elements. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Look at post on "no heat" in this forum will work you through your problem
May 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have water on the bottom of my refrigerator under the crisper drawers. what can be the problem. i bought it in 2001
If its a top freezer you have a frozen drain. If you are not trying to remove panels on the ref then you should shuf the ref down for 24 hrs with the doors open to allow it to thaw out. What is happening is when your freezer defrosts the ice your drain line is plugged and is overflowing down your vents into the ref. 99 times out of 100 this will work. 1% of the time there is somthing obstructing the drain line which would require a tech.
Jan 11, 2010 | Refrigerators
Frezzer working,freshfood side not,ok I stopped motor several times and it work four days and agin the problem. Is there a sensor in the freshfood side? or a little fan inside?Pls Help me
Hi, you got a defrost problem, when to much ice build up after few days,cooling decreases. it could either be your defrost heaters are burnt out, faulty defrost timer, or faulty defrost thermodisc, which are usually at back of freezer, you will have to remove back panel of freezer, and cary out continuity test, to see which ones are defected. the defrost timer sometimes could be found inside of refrigerator compartment or at back of ref. different models, different location, you didn't say what made ref. you got, surely you got a defrost problem, you will need a mechanic to get it check, if your days are hot, or if you got door gasket problem, or someone forgot door half open for few hrs, or excessive hot air getting into ref, could cause that too. before calling mechanic, you will need to empty ref. and unplug for few hrs, clean out all ice, surely it will work, but if problem continues, call mechanic.
Aug 07, 2009 | Refrigerators
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer compartment of refrigerator not freezing
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
