Question about Koss HD 50 Computer Speakers
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
KOSS HD 50 speakers.
Need to know how to connect them to my computer.
Is a Wiring Diagram available?
  • lellya Oct 17, 2008
    Thanks,OK now.
    Lellya
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
May 30, 2011 | Koss HD 50 Computer Speakers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
My GD-50 KOSS SPEAKERS HAVE NO SOUND AN THEY ARE PLUGED IN
you need an external sound card. plug into your pc or laptop then plug in your speakers , hey presto. prob solved. and cheaply to.
Sep 11, 2010 | Koss HD 50 Computer Speakers
My speakers have 2 wire connection and i need to connect them to dell computer sockeys (3 pole jack plug). can i get a circuit /wiring diagram?
Good day sir/maam, if you want to install your loud speakers to your Laptop, you may need a power amp. as shown below. fa67f35.gif
Oct 08, 2009 | Dell WL6000 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
...i lost my installer..
check Koss web site for the driver
Feb 12, 2009 | Koss HD 50 Computer Speakers
WIRING DIAGRAM
yo have wiring diagram :)
send your e-mail address to southener83@hotmail.com
Apr 24, 2008 | Altec Lansing VS2121 Computer Speakers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Oct 16, 2007 | Koss HD 50 Computer Speakers
Koss HD 50 Computer Speakers Logo
863 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
