Question about Sharp R-1610 Microwave Oven
Left fyring pan in oven during cleaning cycle
I started the slef cleaning cycle in the oven and it ran for about an hour and a half before we realized that a pan was lsft in there oven. The smell that remains in our home is very strong. We have had all windows open and doors for over 6-8 hours adn the smell is still strong. Any advice on how to help remove the smell from the home? there is no plastic left in the oven. part of the handle burnt off and incinarated. The pan we through out. Will the oven smell again next time we use it? There are no plastic remain in the oven. It is all "dust" from the process. Please help with the home smell and the use of oven again. thank you
  • 352 Answers
Hi dr68,
The service techs at servepro fire/water damage cleanup and restoration might have a few free suggestions, they deal with smoke damage/residual odor issues every day.
Servpro Industries, Inc.
801 Industrial Boulevard
Gallatin, TN 37066
Phone: (615) 451-0200
Fax: (615) 451-0291
Posted on Oct 16, 2008
Burned microwave smell how do you get ridd of the food smell
The best suggestion I have is to boil water for a half an hour. Be sure not to let the bowl of water run empty. Also, be sure to wipe the condensation out of the oven cavity after this procedure. Generally, though, continued regular use of the oven is what works best for this situation. It just takes time to get the burn smell out.... Good luck!
Nov 19, 2013 | Microwave Ovens
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
This question is about a Whirlpool Gallery in-wall oven, purchased less than 1 year ago. We just ran the 3 hour self-cleaning cycle and now the oven is heating slowly and does not come up to full...
Does it appear both top and bottom elements are still working? If not, then one probably burned out. If your warranty is still valid, then exercise it immediately.
May 15, 2011 | Microwave Ovens
How do I use the self-cleaning function on my Whirlpool Super Capacity 465 self-cleaning oven?
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
In order to get your manual you need the full model number of the oven. This is on a plate located behind the storage door. This pdf,$FILE/4322089.pdf , gives you a picture of where the model and serial numbers are is on page 4 as well as some of the information contained in the serial number on the subsequent pages.
Once you have your model number, go to and enter the model number. This should let you get the manual specific to your oven.
I hope this helps.
Apr 26, 2011 | Whirlpool Microwave Ovens
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
Microwave was run with nothing in it
Well sorry to break it too you, but the oven has been compromised. DO NOT USE! It doesn't turn on because the safety features have worked properly and have saved your home from severe damage. Lesson learned. /shrug
Jun 12, 2009 | Sharp R-930AK Convection/Microwave Oven
Oven operating while empty
Yes, as long as you don't smell any burning, but as always, no microwave should ever run unattended.
Jun 03, 2009 | Microwave Ovens
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Sharp R-1610 Microwave Oven Logo
133 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
