Question about Panasonic KX-T7730 Corded Phone
KX-T7730 - seems locked into a program
Lift receiver line goes on, cant contact extensions without pressing the intercom button then the ext no.
  • Panasonic Master
  • 2,460 Answers
You have a couple of answers, depending on which phone system the phone is connected to.
Pres PROGRAM and dial 1. If the display says PREF. OUT then dial 1 and press STORE then PROG. You now have no PREFERENCE so you get the intercom by default. You get it back or change it by PROG 12 for idle line, or 13x (1-8) for a specific line.
If you didn't get anything with those numbers, try PROG 19 STORE. Then the AUTO ANS key will step you through the choices. That's used on TDA TDE and TAW boxes.
Carl
Posted on Oct 22, 2008
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
    http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
    All releases of Partner
    Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
    This feature is called "Auto line select"
    To program Auto line select:
    From extension 10 or 11:
    Press feature 00
    LEFT INTERCOM
    LEFT INTERCOM
    RIGHT INTERCOM
    Enter the extension number of the extension you need changed.
    press ** (start, star)
    Then the order you want the lines to get picked up
    Then ** (star, star) when done
    When finished, press feature 00 to get out of programming.
    So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
    Easy as pie.
    Aug 20, 2011 | Avaya 700340193 Corded Phone
    Hi i m using th Panasonic KX-T7730 Phone. The light (RED)on top of the instrumernt is lighten always. Why??/If i press the button PROGRAM is asks for some PITS code or something. Can u pls clarify why???
    the light is lit red because you have a message (it is the message waiting light)
    if you want to get rid of the light, try either INTERCOM *700 then your extension number, or INTERCOM 700 your extension number
    as for programming, if you press program, it wants to know what you want to do, so it asks you which feature you would like to program in the form of a 3 digit number
    Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
    I have panasonic kx-t7730. How to set the intercom name and number?
    Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
    It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
    Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-t7730
    Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
    PLEASE vote if this was helpful
    Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
    Programming extensions in the phone
    If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
    The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
    The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
    Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
    Carl
    Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
    I am tring to figure out how to program extensions on our kx-t7737 phone.
    A 773x phone has 24 buttons, 12 are lighted and 12 are Feature. If you want to reassign some of the lighted buttons as extension buttons on the phone, you can press PROGRAM 1 + ext no STORE and that will give you a busy indication whenever that extension is off hook.
    You can program the right side buttons to speed dial the extensions by just pressing PROGRAM ext no STORE. It will dial the extension when you press it if you have intercom dial tone.
    How the button behaves is dependent on which system the phone is attached to. In a TA, you have to start with dial tone on the intercom. In a TAW/TDA you don't.
    Carl
    Sep 28, 2009 | Panasonic KX-T7633 Corded Phone
    How can i program the extensions directly on the phone, without having to dial them.
    It depends on how many lighted spare buttons you have. in a TA type system, you press PROGRAM, press a spare button, and dial 1+ the extension you want to dial and STORE. If you just want a speed dial to an extension, you can program them on the right side by PROGRAM, button, ext, and STORE.
    With the lights, you can monitor the progress of the extension users. It's called DSS (direct station selection) in the manuals.
    If you have a TA or lower system, you have to pick up the handset or press SP PHONE and make sure you're on the intercom, then press the buttons. In a TAW or greater, you can just press the button and pick up the handset or the SP PHONE will go on automatically.
    Carl
    Sep 17, 2009 | Panasonic KX-T7730 Corded Phone
    Cant Change the display name
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
    Basically, there are 2 ways of programming the date
    and time - the short way and the long way.
    KX-Txx 308/824 system:
    SHORT WAY:
    From the Switcboard / Main telephone
    ( ext 101, 10 or 9 ) with the handset on the
    cradle/hook:
    1. Press PROGRAM 0
    2. Enter Date and Time
    ( The format is: yymmdd,
    1 to 7 1=Monday 2=Tuesday etc, hh:mm,
    0 or 1 0=AM 1=PM ) see example
    3. Press AUTO DIAL / STORE to save your changes
    4. Press PROGRAM to exit program mode
    EXAMPLE:
    If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
    100203 2 02:15 1
    LONG WAY:
    From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
    1. Press PROGRAM * # followed by the system
    2. Now press 000 and then SP-PHONE.
    Enter the year.
    3. Scroll to the month with the right scroll key
    (located at the right bottom corner of the phone).
    To change the month use the AUTO ANS / MUTE
    button.
    4. Now scroll right again and change the date and
    day.
    To change the day, again use AUTO ANS / MUTE
    5. Scroll right again and the time will appear.
    Set the time.
    To change am/pm scroll to it, and again,
    use the AUTO ANS / MUTE button.
    6. Press PROGRAM to exit program mode and you
    are done.
    Jun 27, 2009 | Panasonic KX-T7730 Corded Phone
    Seems to be locked into a program - do not have a manual
    If using the KX-T7730 phone on a Panasonic 308/616/824 system press Program 11 and then AUTO DIAL / STORE . Press Program to exit programming mode.
    If this answer was helpfull please vote
    Thank you.
    Oct 15, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    170 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
